Username: Drivingreckless Nuthingsville,
Florida
United state...
Post Number: 2 Registered: Apr-06
Tuesday, April 04, 2006 - 00:13 GMT how to wire a audiobahn a6004v and two p212s4???
Username: Lbeckner Tulsa,
Ok
Usa
Post Number: 892 Registered: Oct-04
Tuesday, April 04, 2006 - 02:15 GMT that amp is a 4 channel so you will need to bridge it. bridge the amp down to 2 channel and wire a woofer into each channel
Florida
United state...
Post Number: 17 Registered: Apr-06
Tuesday, April 04, 2006 - 02:30 GMT yes but the dilemma is how should i bridge it to 2 ohms or four ohms and also is overpowering subs dangerous?
Ok
Usa
Post Number: 896 Registered: Oct-04
Tuesday, April 04, 2006 - 04:23 GMT on the speaker outputs on your amp the bridged mode terminals should be marked. there may also be a switch to change it into bridged mode(2 channel). i dont think that u have to worry about over powering those subs with that amp.
Username: Makmillion United States
Post Number: 12 Registered: Apr-06
Wednesday, April 05, 2006 - 05:47 GMT Your only going to get a little over 430 watts out of that amp.. they won't blow using that amp, if you set it up correctly. Wire it at 4 ohms, it's not stable to 2 in bridged mode.
Username: Tjmutlow Post Number: 1860 Registered: Sep-05
Wednesday, April 05, 2006 - 10:15 GMT you can not wire a single 4ohm sub to 2ohms
Post Number: 20 Registered: Apr-06
Wednesday, April 05, 2006 - 12:22 GMT "how to wire a audiobahn a6004v and two p212s4???" I believe the post says (2) two P212S34 subwoofers.
Username: Johnnylemoine LaPlace,
Louisiana
United States
Post Number: 683 Registered: Aug-04
Wednesday, April 05, 2006 - 15:20 GMT 2 single 4 ohm subs can be wired to 2 ohms. parallel.
Username: N2audio Lawrence,
Ks
Post Number: 784 Registered: Mar-04
Wednesday, April 05, 2006 - 15:25 GMT one sub per bridged channel - that's all there is to it
Louisiana
United States
Post Number: 685 Registered: Aug-04
Wednesday, April 05, 2006 - 15:28 GMT oh sh*t, yeah optidriven, ur right, i didnt realize he was trying to use a 4 channel amp. yeah just do wut opti said, one sub per bridged channel.
Ok
Usa
Post Number: 915 Registered: Oct-04
Wednesday, April 05, 2006 - 18:21 GMT that amp is a 4 channel so you will need to bridge it. bridge the amp down to 2 channel and wire a woofer into each channel
Florida
United state...
Post Number: 18 Registered: Apr-06
Thursday, April 06, 2006 - 18:39 GMT THANK YOU FOR UR HELP IM GUNNA TRY ALL THE WAYS AND SEE WHICH ONE SOUNDS BEST....ALSO AUDIOBAHN SUX SO WUT AMP WOULD BE BETTER TOP PUSH THOSE TWO P212S4'S PLZ I NEED UR HELP JL/ROCKFORD/PG HELP???
Ok
Usa
Post Number: 925 Registered: Oct-04
Thursday, April 06, 2006 - 21:27 GMT You need a two ohm stable amp. plenty of good name brands on woofersetc.com and ebay
