Boss Audio 5x7s?
Username: Sweatyogre
PA USA
Post Number: 41
I'm looking to upgrade the door speakers in my Explorer, but I'm on a fairly low budget. Anybody know what's the word on Boss Audio BL5750s? I plan on running them way under the RMS wattage, since I don't have the money for an amp for them yet.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 387
sweaty don't do that man cuz you won't be happy at all and will be without cash to buy something better. I recommend you a cerwin vega component set, they're just 60$ and 70 shipped i think, and if you want, you can buy some profile amp "not bad for that little amount of power" and there you can have some good sound, but don't buy that boss Cr@p
PA USA
Post Number: 42
$60 for two? I need 4 of them. If that's my best bet for 5x7s on a budget though, I can pretty easily get $140.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1718
i'd rather keep factory then get Boss anything.
PA USA
Post Number: 47
A dude at Circuit City told me that Polks would do a good job of keeping up with my sub, and I figured he was being straight with me since he told me Jensen and Sony both suck, which I already knew.
