New member Username: DadydolasPost Number: 9 Registered: Mar-06 | wanted everybodies opinion on this setup and how they think it will sound thanks |
Silver Member Username: GoatinU.S.A Post Number: 664 Registered: Jan-06 | no offense but not all that good. Jensen HU's are a waste of money. That amp is not powerful enuff for all 3 subs. 2 subs to that amp at 1 ohm would be louder than 3. If you are an absolute Newb to car audio you might like it. Be careful with those infinity reference's I hear they crack easily. |
Silver Member Username: DelsolePost Number: 264 Registered: Feb-05 | be nice god damn your harsh dude theres gotta be a better way to say it |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 765 Registered: Mar-04 | Doesn't sound too bad to me. Depends on the quality of the Jensen, they make some OK HU's, but they make some super cheap ones also. Looks like you're going to pay no less than about $50 shipped for the subs so -- Subs - 150 Amp - 150 HU - 100 Sounds fair to me. Three subs at 1.3 ohms should work well. ~250w a piece is more than enough to get them moving. |
Bronze Member Username: Jeffless600Post Number: 75 Registered: Feb-06 | Nothings going to sounde that crappy just the subs wont get getting there full potential wattage..jensen head unit= cheap, but it still gets the job done usually... |
New member Username: ZoopunkFresno, California USA Post Number: 2 Registered: Apr-06 | lol u need more power to amp and iv got a question i ahve an interfire amp heres is a link www.interfireaudio.com/products_ampli_ib2.htm amp number is IB2900C till tell u wat i have, i just need to know wat kind of power supplie i need to get it running |
