Should i upgrade to knukoncepts 1/0 power wire from cheapy 4 guage
Username: Quick_94gt
Post Number: 11
what do you guys think? my sub amp is a directed 1100d and was wondering if upgrading from my cheap no name brand 4 guage wiring which looks to be mostly insulation to knukoncepts.com kolossus power cable help out the system in any way??? or should i just buy some of their 4 guage kolossus wire?? do i need 1/0 wire? i have a total of two amps, the directed 1100d and 4500 for the highs, by the way does anybody have good things to say about knukoncepts?
Username: Fandim
Reno, Nevada United State...
Post Number: 838
One thing for sure - it cant hurt.
Username: Suleman36
Maryland U.S.A.
Post Number: 3417
Check with the chart there to see if you need to.
http://www.the12volt.com/info/recwirsz.asp
Username: N2audio
Lawrence, Ks USA
Post Number: 766
You're looking at around 1600w rms possible power - depending on what you're running and how it's wired.
With 500w rms I'd definitely say 1/0 would be the way to go. 2 would be plenty, but 1/0's not much more and a lot easier to find.
cool calculator -
http://www.bcae1.com/images/swfs/wirepowercalculator.swf
