Bronze Member Username: BassheadjoshUtica, MI US Post Number: 26 Registered: Feb-06 | The manual calls for 2 cubes er sub...I ordered the SPL remakes of the W6...3 12's for $160 shipped...not too shabby. Now I want to port them...I figure 6 cubes, roughly 30 hz...only problem is I can't wuite fit 6 cubes in...would it be a big deal to cut it down? If so I will just have to do some extreme calculations....maybe a box that takes up the entire back of the trunk and then has a half as tall section in the front half of the car...its a 91 cutlass and has trunk arms which is the problem...any thoughts would be awesome |
Bronze Member Username: BassheadjoshUtica, MI US Post Number: 27 Registered: Feb-06 | Sorry, meant to say that it would be a quazi L shaped box. Side view: ! ----------------- ! ! ! ! ! ! ! !------------- ! ! ! ! ! !--------------------------------! watcha think? This is a last resort...subs firing up cause its a shallow trunk.... |
Bronze Member Username: BassheadjoshUtica, MI US Post Number: 28 Registered: Feb-06 | dang it that didnt work....lol im outa ideas |
Silver Member Username: Matt12490Benicia, California USA Post Number: 492 Registered: May-05 | when did you get those subs?? |
Bronze Member Username: BassheadjoshUtica, MI US Post Number: 31 Registered: Feb-06 | just bought em last night. still in shipping |
Silver Member Username: Matt12490Benicia, California USA Post Number: 497 Registered: May-05 | where did you buy them??? |
Bronze Member Username: BassheadjoshUtica, MI US Post Number: 32 Registered: Feb-06 | www.mycarjams.com....look under spl then subs, etc...you get the picture. I couldnt believe how cheap they were |
Bronze Member Username: BassheadjoshUtica, MI US Post Number: 33 Registered: Feb-06 | sorry bad link... just go to www.mycarjams.com that link should work. anyways I still need hel with this box... |
