Bronze Member Username: HighstonePost Number: 73 Registered: Mar-06 | can someone tell me how to wire a AUDIOCONTROL LC6 channel output converter. http://www.sonicelectronix.com/pictures.php?id=6359 it has the front, rear, and subwoofer outputs. ** where would the subwoofer output wires come from? Link for the ebay auction:http://cgi.ebay.com/AUDIOCONTROL-LC6-6-Channel-OEM-Line-Output-Converter_W0QQite mZ9705117091QQcategoryZ79842QQrdZ1QQcmdZViewItem the auction says that it can accept 400 watt signals.. What does that mean? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11463 Registered: Dec-03 | go to jlaudio.com and RTFM? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11464 Registered: Dec-03 | * audiocontrol.com |
Bronze Member Username: HighstonePost Number: 74 Registered: Mar-06 | The website says it can accept speaker level inputs upto 400 watts. WHAT DOES THAT MEAN? WOULD I BE ABLE TO HAVE 2 KICKER L7s WITH THIS? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11468 Registered: Dec-03 | it means it takes input signal from radios with up to that much power. yours is probably about ten watts, so it's fine. your amplifier can be any size. solobarics suck |
Bronze Member Username: HighstonePost Number: 76 Registered: Mar-06 | ohhh.. thanks. but where would the subwoofer wires come from? I don't believe that my factory radio will have the subwoofer wires. (it will only have front and rear (right/left)) so what the deal with that? |
