Help, just a quik question...
Username: Toxus
Is it possible to connect car speakers up with a normal home cd player?
thanks for any help...
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 886
Sure. You'll need boxes for them and a reciever that produces at least like 10W.
Username: Safe_cracker
Chicago, IL US
Post Number: 636
You may want to use 8ohm versions or double up the amount of 4ohm speakers you already have not to mention a passive crossover will be needed. Most home amplifiers are designed for 8ohms, Polo.. :-)
