This box be good w/ my 2 swx-1242d's?
Username: _jay_
Post Number: 45
Our boxes are made with pride in our own facility here in the USA. They are constructed with the highest quality MDF that meets our rigid standards. Unlike our competitors we do not use pressed cardboard or rice wood materials from overseas. Using top quality MDF makes the enclosure much more rigid and gives your subwoofer a great platform to perform at it's best. This makes our boxes a little more expensive but you truly do get what you pay for.
Our boxes are made from precision cuts of MDF. They are then liquid nailed, nailed and completely sealed. We then wrap them with high quality charcoal carpet that matches most vehicle interiors.
We guarantee you will not only see a difference in the quality of the boxes we build, but you will hear the difference and that is what is it is truly all about.
Brand: Sub Boxes
Condition: New
Dual 12 Inch: Yes
Sealed: Yes
Vented: No
Tuned Bandpass: No
Includes Terminal Cups: Yes
Fits Square Sub(s): No
Fits Round Sub(s): Yes
Fits Cars: Yes
Fits Trucks: No
Constructed With: High Quality MDF
Enclosure Volume: 1.3 Cu. Ft. Per Chamber
Dimensions: 12H x 28W x 12TD x 17-3/4BD
Precision Constructed with MDF
Carpeted Box for added protection
Dimensions 12 H x 28 W x 12 TD x 17-3/4 BD
Includes Built-In Terminals
Dual 12" Box
here is a pic
http://a763.g.akamai.net/7/763/1644/v001/app.infopia.com/img/image/fp/extra/1/VP ID/1330840
Username: Jmloughrey
Farmington, CT
Post Number: 1465
well, do the specs of the box match up with the specs on the sub?
Username: _jay_
Post Number: 46
yea..i'm just trying 2 figure out how well it will stay together lol...
