Pioneer DV-563a vs Pioneer DV-588a
Username: Dukedog223
I've had a DV-563a for about a year now. I think it's a great player for the money. I couldn't really find any MAJOR flaws until a couple days ago. I bought The Flaming Lips' new DVD-A mix of "The Soft Bulletin." Guess what? No audio. After a minute of internet scouring, I discovered that the 563A has a well-documented firmware flaw. Even with the patch, some DVD-A discs may not play. Bogus.
Now my question - Does the newer Pioneer model, the 588a fix these problems? Any 558a owners out there?
Username: Sem
New York USA
Post Number: 557
Mark,
I'm not sure about the answer to your question about the 588a but I believe Pioneer will upgrade the firmware in the 563a for three years. During this time I think the only thing you're responsible for are the shipping costs. The last firmare upgrade on the 563a that I'm aware of brought it to 1.906 - someone posted sometime back how to display your current firmware version, search around to find it. I have the 563a and since upgrading to 1.906 I haven't run across any disc it won't play, but I don't own "The Soft Bulletin"
Thanks for the info, Sem.
I received an email today from Pioneer:
"The information on Flaming Lips "The Soft Bulletin" has been reported previously and forwarded to the Engineering Dept. for investigation and is currently awaiting their response."
Well, at least they're trying...
Username: Kewl
Add the new Donald Fagen album, Morph the Cat, to the list of unplayable DVD-Audio on the 563A: at least they package it with a regular CD-Audio version. In any case it's back to the store to exchange with the plain old CD-A.
It's too bad, because Donald Fagen previous effort, the 2003 Steely Dan album, Everything must go, plays fine on the 563A. What pisses me off with the firmware upgrade is to have to send in the player: I'm pretty sure the thing is upgradable with a CD or DVD with the firmware on it...
Too bad also that the 563A is a smoother player than the 588: I found the mechanics of the latter very loud.
Username: Sem
New York USA
Post Number: 566
I am very sory to hear that, Kewl. I was planning on picking up the 'Morph The Cat' Special Edition disc. I already had my 563a in the shop for the 1.906 upgrade and am not sure I want to keep going through this same routine every 18 months. Perhaps it's time to look for another player.
Username: Sem
New York USA
Post Number: 572
Mark and Kewl,
If you're still having a problem with "Morph.." and "..Lips" I believe both will be fixed with the upgrade to firmware version 1.906 There is an iso image file available out on the web that you can download, burn to cd and stick in the player and magically updates it to the firmware to 1.906
Thanks for the heads up, Sem. I'll be looking for that file.
Got the ISO, installed the patch to 1.906. "The Soft Bulletin" plays! Thanks a ton, guys.
Username: Kewl
Post Number: 7
http://www.quadraphonicquad.com/forums/showpost.php?p=42966&postcount=272
This is not an April Fool...
Username: Arnold_layne
MadridSpain
Post Number: 446
Resolves problem with Bowie album "David Live" too. Patch is valid for European DV-565A, region code 2 is maintained.
Cheers
AL
