ok i dont know much bout amps and stuff and i was wondering how it will effect my car battery??? i was also wondering if i should get a cap and what exactly that will do? thanks fer the help!
the car will pull the power away from the battery and drain it unless you have a proper HO alternator. The capacitor would just put more strain on your alternator so dont get a cap. if you wanted to know, the cap just levels out the power kindof, and people would say that "it will make your subs hit harder"
i know that it doesnt make it 'hit harder" i just said that i have heard people say that which is ridic. it makes the amp more efficient is a better way to put it
