Bronze Member Username: Dj_excitePost Number: 47 Registered: May-04 | did jl audio take there 4 ohm to 2 ohm DVC bridging instructions off of there website on there website it states 4 ohm to 1 ohm thats too low for the garbage amp i got for free is it + to-, + to -, then run parallel outsied or inside box + +, --? to get 4ohm dvc subs to 2 ohms, i dont remember |
Gold Member Username: RovinTrinidad & T... Post Number: 6897 Registered: Jul-05 | if u need 2 wire any sub combo http://www.the12volt.com/caraudio/woofer_configurations.asp |
