My cd player won't eject all of my cd's only certain ones....it will say eject , load eject load and then error .... i dont think its my alpine i think it may be that the guy that installed it put it in to tight but i dont know.. any suggestions?? ...thanks
Defenatly in too tight... I had the same problem with my ALPINE. Remove the alpine from your dash and then try to eject problem CDs. If the deck isn't ruined, it should eject them. My eventually got ruined, so I sent it to Alpine and they fixed it for free.
