Locked AC Delco for 2001 Cavalier
Username: Kyrock
Virgie, Ky USA
I bought a cd/radio from a junk yard, which came out of a 2001 Cavalier. I am trying to replace a radio in my 2001 Cavalier. It worked great while the key was turned to AC, but when I started the car, the radio locked. Is there anyway to unlock it without taking it to a dealer?
Username: Illuminator
Post Number: 2767
There is, but I don't know it and probably nobody else except for the dealer knows it. You'll have to get a code from the dealer.
Username: Kyrock
Virgie, Ky USA
I figured I might, but just trying to save a little $ if possible.
Username: Jkclassic
Hold in buttons 2 & 3 at the same time for 5secs. Four #'s should appear. What are the #'s?
Username: Kyrock
Virgie, Ky USA
When I hold the two buttons, nothing happens.
Username: Jkclassic
Post Number: 7
The wrong radio code has been entered too many times. You must leave the radio powered up for at least an hour and then press buttons 2&3 at the same time and you should get a four digit #.
Username: Jkclassic
Post Number: 8
Did you ever get thoses #'s to come up?
