Upgrading electrical system help
Username: Cocizzie
i have an 86 monte carlo ss and the stock alt is only 70 amps. im planning on running two amps hifonics generatin xx hercules 2000 rms@1ohms and a hifonic xx olympus for the highs.my question is how big of an h.o alt will i need and will i need a second battery?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1516
well, not sure on your total wattage but
watts/12.6V = amps of current draw. plus the 40-50 for the car. thats about the output from a Alt you'll need.
but 4000 watts is a LOT. you'll prob have to look into a dual alt kit or something!
Username: Jeffless600
Post Number: 64
What subs do u plan to run? 4000 is alot for an old carrr
Username: Cocizzie
Post Number: 9
have the amps havent found the subs ,do you have any suggestions? i was considering kicker L7's or alpine swx maybe mtx 9500 or treo ssx but im open minded to any good sub i want a mix of spl and sq in a 12 inch woofer
Username: Cocizzie
Post Number: 10
3000 watts olympus generation xx is a 1000 watt 4 channel amp hercules is 2000 watt at 1ohm but i have no problem running it at 2ohms which is 1500rms
