New member Username: CocizziePost Number: 4 Registered: Mar-06 | i have an 86 monte carlo ss and the stock alt is only 70 amps. im planning on running two amps hifonics generatin xx hercules 2000 rms@1ohms and a hifonic xx olympus for the highs.my question is how big of an h.o alt will i need and will i need a second battery? |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 1516 Registered: Feb-05 | well, not sure on your total wattage but watts/12.6V = amps of current draw. plus the 40-50 for the car. thats about the output from a Alt you'll need. but 4000 watts is a LOT. you'll prob have to look into a dual alt kit or something! |
Bronze Member Username: Jeffless600Post Number: 64 Registered: Feb-06 | What subs do u plan to run? 4000 is alot for an old carrr |
New member Username: CocizziePost Number: 9 Registered: Mar-06 | have the amps havent found the subs ,do you have any suggestions? i was considering kicker L7's or alpine swx maybe mtx 9500 or treo ssx but im open minded to any good sub i want a mix of spl and sq in a 12 inch woofer |
New member Username: CocizziePost Number: 10 Registered: Mar-06 | 3000 watts olympus generation xx is a 1000 watt 4 channel amp hercules is 2000 watt at 1ohm but i have no problem running it at 2ohms which is 1500rms |
