http://audioforum.termpro.com/ubb/ultimatebb.php?/ubb/get_topic/f/8/t/021928/p/1 .html damn its f\/ckin huge, i guess from what i read the motor is based off the shocker sig motor.
Ruler of DBDragg Now more than ever the name Earthquake has become synonymous with winners circle, ruler of DBDrag, the one to beat etc. For 2005 we elaborated on the bar and raised it so high it wont be touched exceeding even our best. The HoLeeS-15 competition subwoofer weighs in at 100lbs. net. It packs four superior spider units, a 4" dual voice coil with a flat wire surface, patented PSP terminals, a high roll surround and killer looks. If your ready bring home 1st place your at the right place. If your using anything else you'll just get second and be the first looser SPECS Sensitivity 85.0 dB Qts .338 Fo 25.475 Hz 15,000 Watts Peak 7000 Watts RMS each coil Over 4" long throw excursion Dual (2x1ohms) 4" x 8" High Temp military grade flat wire voice coil. (4)Quad Nomax / Romax spider construction 8 gauge speaker connections 112lbs. Reccomended Enclosure 6-10 Cu Ft 1" MDF Minimum Port Surface 107.25 sq in Port Length 18.5" Depending on the tuning frequency
i found the specs on there website, looks like a monster.
arn't RE and MTX co brands(i dont really know the name for it right now...drinky drinky). or something like RE buys stuff from MTX...maybe i just made that up.
