American legacy II LA690 amp: i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever i bridge the amp it shuts off and i don't want it to
it's shutting off for a reason. What speakers are you trying to run? Do you know what impedance they are wired for? Where is the gain set? When bridged that amp is only stable at 4 ohms mono and will/should shut down at impedances lower than that.
legacy is about the cheapest brand out their along with pyle. trust me ive had that $hit. spend the extra money its deffenatily worth it dont be a cheapass
