Bronze Member Username: Cadillacstyle0Post Number: 25 Registered: Apr-04 | kicker 01c104 125w rms 4 ohm single voice coil or alpine swr - 1021d 100-300w rms dual 2 ohm voice coil the amp is a punch 45 im not really sure what ohm level its stable at so if you can help me there it would help also thanx what ohm level is a punch 30 hd stable at thanx |
Anonymous | hmmm... i'd probably go with the alpine myself. i'm not sure what model that kicker is but by the rms ratings, i'd go with the higher one of alpine because you can always upgrade you amp to get more bass whenever you have the dough. |
Anonymous | try these wen u can afford it: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=4950&item=3093621470&rd =1 |
