Silver Member Username: Thomas_gNM Post Number: 148 Registered: Oct-05 | Can you guys name a few bad azz SQL subs that sound crazy but arent that expensive thanx! |
Bronze Member Username: Ryanshaw3ballPost Number: 13 Registered: Mar-06 | alpine type r around $140-170 and will get pretty loud as well. also resonant engineering se |
Gold Member Username: PelonaAlabama Post Number: 1056 Registered: Dec-05 | kicker cvr and cerwin vegas |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6287 Registered: Jul-05 | whats not expensive?? Crystal Comp X (450) RE XXX (650) or Kicker cvr (100) RE SE (200) |
Gold Member Username: Jonathan_fGA USA Post Number: 5858 Registered: May-04 | Peerless XLS or XXLS are great for the money: http://www.madisound.com/cgi-bin/index.cgi?exact_match=yes&product=PEA&cart_id=8 255291.7468 |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3387 Registered: Feb-05 | RL-P 12 Sound Splinter / www.soundsplinter.com |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 3311 Registered: Oct-05 | treo ssi |
Silver Member Username: Sw9152Michigan Post Number: 253 Registered: Feb-06 | eclipse titanium- $350 off electronic giant |
Bronze Member Username: ShowridesHartford, CT USA Post Number: 54 Registered: Feb-06 | Mag 12 or 15. What do you considser exspensive though? |
Silver Member Username: SixFlint, MI U.S.A. Post Number: 464 Registered: Oct-05 | Ascendant Audio Arsenal 12" or 15" for $220 or $275 new. I find these to be the epitemy of pure SQL... |
Silver Member Username: AlteraudiousaConcord Post Number: 495 Registered: Jan-06 | if what you consider "not expensive" is between 400-600, get a Stereo Integrity Mag 12 or 15. If "expensive" is something like 300$ or less, get Dayton MKIII Titanic, SoundSplinter Rl-p, or ED Ov.2. |
Silver Member Username: Thomas_gNM Post Number: 149 Registered: Oct-05 | Between $200 and $400 each. No more than $400. Where can i look at these subs. Ascendant Audio Arsenal? treo ssi? Thanx guyz. |
Silver Member Username: DelsolePost Number: 239 Registered: Feb-05 | http://www.ascendantaudio.com/arsenal15specs.html |
