2 alpine type R 12" subs , what amp should i use?
Username: Mazdaemon167
Oceanside, NY United States
i just bought 2 Alpine Type R 12" 4 ohm 500 watt RMS subs . I really like the alpine 1000 watt mono amp and was thinking about rigging both subs to the one amp, first is this possible, and second is it a safe idea? If this is not possible, I was going to get 2 of those alpine amps and have 1 amp for each sub. The power rating for each amp per channel into 4 ohms : 500W x 1. Is this too much power for the subs to handle? Can someone please give me their opinion and an idea? Thank you very much.
Username: Rovin
Trinidad & T...
Post Number: 6755
well since no1 else is answering -
i own 2 of those Rs & they can easily handle MORE than 500wrms they r rated @
most common amps (if u buy 2 4ohms dvc models of subs) ppl on this forum use r either kicker 1200 or orion 1200d amps with no problems whatsoever . Port those subs & u will be 1 happy dogg ...
