How does LFE work anyway?
Macky
Just when I thought I knew how this Onkyo HTS-650 worked, you guys have me second guessing myself.
I have a coax going from DVD player to Onkyo.
I have the DVD bitstream set for Dolby Digital not D-PCM and DTS is set to on.
The way you are all describing LFE, I am confused as to whether it is something that is enabled in Mode 3 only, or if you somehow use the 6 RCA cables output from your DVD player to your Onkyo.
I guess what I am asking is, can you get LFE using Coax or Optical?
Thanks for clarification...
Yes you can get LFE from both Coax or Optical since both are digital. Just make sure on the HTS-650 receiver that the dvd player source is set to either optical or coax input for sound, and you should be fine.
