How would it sound?
Username: Killer44
Ontario Canada
Post Number: 441
One mmats 12inch pro series(250rms) in a 1.25 cuft sealed enclosure pushes be a BX605D which will be putting out 300@20hms (sub is dvc 4ohm) this will go in a reg cab mazda(my brothers truck)...
Username: B101
Queen City, NC USA
Post Number: 1892
it should SLAM hard... u will be surpised!
Username: Killer44
Ontario Canada
Post Number: 442
which do u think would be louder b, his system(my brother) or mine which is 2 compvr10's in about the same size boxes each with a orion 600d running them....?(mine are in a reg cab s10)
Username: B101
Queen City, NC USA
Post Number: 1896
u have 2 subs & double the power he has, so on paper you should have the edge.. u have twice as much cone area, and double power...
dont be surpised if his still sounds just as loud as yours! mmats are SPL subs, so its going to get loud!
Username: Killer44
Ontario Canada
Post Number: 444
well both of the subs are mine...the mmats used to be in my probe and it pounded with only 180 watts but it was in a bandpass enclosure...so i was wondering if i should give him my 10"cvr's and use the mmats for my truck?
Username: B101
Queen City, NC USA
Post Number: 1901
i would try both in your truck, then give him which ever u didnt like the most! its hard to tell u which will be louder online.. to be exact u will need to measure the dbs, but by ear u will know what u like!
Username: Killer44
Ontario Canada
Post Number: 449
hey B how much power do u think i could throw at that mmats without it dying out? like i mean for everyday use, not a single sound burp...thanx killer....
Username: Killer44
Ontario Canada
Post Number: 452
bump...
