I would like to buy a new player....Please help and advise
Username: Nero041001
I currently own a DKdigital dvd339, and I would like to buy another player with component out
I have found this:
[url]http://www.club-dvd.net/modules/wordbook/entry.php?entryID=93[/url]
2.[url]http://www.multizoneav.com/shop/customer/product.php?productid=19735&partner=kel koo[/url]
4. [url]http://www.superfi.co.uk/index.cfm/page/moreinfo-2.cfm/Product_ID/1829/source/ke lkoo[/url]
5. [url]http://www.pixmania.co.uk/uk/uk/86330/art/yamaha/dvd-divx-dvd-s550-player.html[/url]
6. [url]http://www.pixmania.co.uk/uk/uk/99652/art/samsung/dvd-hd850-high-definition.html[/url]
7. [url]http://www.pixmania.co.uk/uk/uk/157741/art/lg/dvx9900h-high-definition.html[/url]
8. [url]http://www.digiuk.com/productdetail.asp?id=4139&c=2052811&guid=&s=&sm=[/url]
Are there any players with similar specs to any of the above that someone could recommend??
Though I am not really bothered about the HDMI connectivity, as my LCD doesnt have a HDMI or component connection (It has VGA), and my projector is only the Panny AE200, so the resolution wont make that much of a difference.
[B]I definately want it to have:[/B]
Multiregion/RCE compatible (pref with a remote hack or firmware upgrade that doesnt affect other features badly)
able to play dvdr/rw/+/- and DL+ / cdr/rw / mp3/jpeg dvd
divx (hopefully most versions up to latest)/xvid/mp3/dvd/SVCD (not bothered that much about SVCD/VCD
component out (YUV is it?) (for my projector, Panny AE200)
RGB Scart (for my tv)
DD/DTS compatible out through Coaxial and optical (I usually use coaxial)
analog audio out too with composite video (as I connect this to a portable)
And would like it to have a great picture and sound through my lcd tv/ projector and amp
[B]Can anyone help me find/or choose one of the above dvd players?? That would be the best sound and picture for my movie needs coupled up with my sony str de697 av reciever[/B]
And recommend some more that I may have missed (and where to buy them) :lease: OR would it be my best option to go with the Toshiba 350E?
Even though I have both there I dont see much difference between the samsung 850 and 950?
It seems from the reviews here:
[url]http://www.videohelp.com/dvdplayers[/url]
That the 850 out peforms the 950?
Can anyone confirm this
The specs I need are 3rd post from the top of this thread :-)
What would give the best picture and sound (RGB SCART & Component / coaxial) out of the:
Toshiba/Samsung/Yamaha
Also been looking at the Samsung p750 and p355, is that a good idea? or should I stick with looking at the 850/950? Would they give a better picture / sound
Are there any around this price range with the specs I need that would be better for picture and sound than those mentioned above??
I do not want to risk having any noisey drives though
As much help/advice and recommendations will be most appriciated, and I would like to come to a decision by the end of today
Thank you in advance
tris
Anyone??
tris
Username: Datsafact
http://www.oppodigital.com/
