New member Username: FfmikePost Number: 4 Registered: Mar-06 | If i have a fortec lifetime satelite receiver, does this mean i get HD? I have an HD ready TV but it doesnt seem to get HD or maybe its just my TV (panasonic PT-45LC12) |
New member Username: EhdmiPost Number: 10 Registered: Mar-06 | From what I read about that receiver it's not a HD box. If you have a HDTV ready TV, you need a separate HD tuner to get HD reception. I would recommend looking for a HD Tuner since your TV doesn't have it built in. You possibly have a different box from the one I looked at though. Keith Http://www.eHDMI.com |
New member Username: Edu_da_floridaPost Number: 7 Registered: Dec-05 | Mike, you will also need a special dish. |
