NEED a 700-800 watt rms @ 4 ohm amp for my ID MAX 12
Username: Suleman36
Maryland U.S.A.
Post Number: 3335
Just list some good amps in the $300-$400 price range to run a ID MAX 12 dual 2 ohm versian. Im going to wire it into 4 ohm.
It can be a good class D or AB but as long as its clean and at 4 ohm. Just want to look at all your suggestions.
Username: Safe_cracker
Chicago, IL US
Post Number: 471
Pheonix Gold Xenon 1200.1 1200 rms into 1-4 ohm. If it is too much power, turn it down. ID Max can handle 1000 rms but would not recommend much more, Polo..
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6083
ARC Audio 1500D-R
Avionixx AXT 800.2
Brax X2000.2
Cadence Z9000
MTX Thunder 81000D
Treo SSXD1500.1
BTW why do u want to wire at 4 ohms, u no it will be more expensive
Username: Suleman36
Maryland U.S.A.
Post Number: 3336
For Sound Quality its probably not audible but is better in long term for your amp if you run it at 4 ohm as it runs cooler and with less heat.
I was considering the Arc Audio 1500-XXK but im not sure. It usually runs around $500 or so.
Username: Suleman36
Maryland U.S.A.
Post Number: 3337
Besides, i dont need 900 watts rms. 800 is the max i will put to the ID MAX 12.
Username: Suleman36
Maryland U.S.A.
Post Number: 3338
Alpine MRD-M1005 is another amp that does about 500-700 between 12.5-14.4V / has anyone used this ?
Username: Carguy
Post Number: 5391
Orion 275G4 or Zapco Ref 750.2.
Username: Rovin
Trinidad & T...
Post Number: 6589
well the somewhat obvious choice would be a used 1000/1 on ebay maybe .....
Chicago, IL US
Post Number: 479
Dude that is for class A/B amps, a good class D doesn't run on the edge like others, thats why there is so little heat produced. Polo.
Username: B101
Queen City, NC USA
Post Number: 1774
its just preference here Polo.... I think MO knows the difference..
I would suggest a PPI for some IDMAX....
Username: Suleman36
Maryland U.S.A.
Post Number: 3340
I will pass on the alpine. I meant the older mrd-1001 which was better.
275G4, why dont you find me one isaac / goodluck :-)
1000 watts is more then needed. Im going to look for a 600-800 watt amp.
Its just difficult to find it since most amps these days are 1 or 2 ohm for subs. Zapco is not in my price range but thanks.
I shouldnt have sold my ppi pcx 2200. That whould have been ideal. 800 x 1 @ 4 ohm
Username: Tjmutlow
Post Number: 1662
just use a 1ohm mono amp, like a orion 600d
Username: Suleman36
Maryland U.S.A.
Post Number: 3341
Im leaning towards the older Rockford Fosgate 601 and 801s 2 channel amps.
601s / 150 WATTS RMS X 2 AT 4 OHMS
300 WATTS RMS X 2 AT 2 OHMS
600 WATTS RMS X 1 AT 4 OHMS IN BRIDGED MONO
801s / 200x2 @ 4 Ohms RMS
400x2 @ 2 Ohms RMS
800x1 @ 4 Ohms Bridged RMS
More then likely i will get one of these. They are alot better then the current rockford anyways.
Username: Rovin
Trinidad & T...
Post Number: 6598
ya - but i was thinking with a 1000/1 means the amp would have headroom & run quite cool ......
Username: Suleman36
Maryland U.S.A.
Post Number: 3342
Yes, thats true rovin. However i plan to save some money and get good class AB performance out of the Rockford 801S or 800a2 which are both stable at 4 ohm bridged and are extremely underated and put out close to 1000 watts rms. They are also built in the USA.
Chicago, IL US
Post Number: 482
I agree with Rovin, get a slightly larger amp and turn it down. Having an 800 wrms amp running at 800wrms is worse then having a 1000wrms at 80% now which one is on the edge? The PG X1200.1 is pretty cheap and sounds great, JMHO..Polo..
Username: Carguy
Post Number: 5392
eBay 8045407346.
It's Orion 2250SX amp going for $305 and ending in 3 hours.
The same amp GlassWolf has in his car.
Username: Suleman36
Maryland U.S.A.
Post Number: 3344
No thanks isaac. To big and heavy looking. I will stick with the Rockford 601s or 801s or 800a2
Just deciding out of those models right now. My friend had a couple at one point and they are really nice amps and built very good.
Username: Carguy
Post Number: 5393
The best deal I saw last year was Zapco 1100.1 amp for $280. I went for Zapco 750.2 amp instead.
Don't think you'll ever get another Zapco amp for under $300.
Username: Tjmutlow
Post Number: 1666
If you think those fosgates are much beeter then the new stuff, your wrong, you need to go back even farther for the good fosgate stuff, like the ones that look like footballs. and if you were really smart, and wanted old great amps, the orion 250r or the 275r
Username: Suleman36
Maryland U.S.A.
Post Number: 3347
I dont think so either.
Chicago, IL US
Post Number: 485
Ya, I use to love the old Orion Cobalt 230's, great little amp..Polo. :-)
Username: Suleman36
Maryland U.S.A.
Post Number: 3349
Im going to go with the RF 601s and get it brand new directly from RF thru http://stores.ebay.com/High-Desert-Audio-Store
comes with a 90 day warranty.
601s - 600+ x 1 @ 4 ohm bridged
801s - 800+ x 1 @ 4 ohm bridged
Which one do you guys think i should get for the ID MAX 12
Username: Lil_jon
Post Number: 350
i got 1 of those man this amp is off the hook
Username: Suleman36
Maryland U.S.A.
Post Number: 3351
Actually i bought the 800a2 model.
http://www.carreview.com/mfr/rockford-fosgate/amplifiers/PRD_49698_1806crx.aspx
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 764
class a/b? sweet
Username: Suleman36
Maryland U.S.A.
Post Number: 3354
yeah class a/b and the better built rockford amp from 1999.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 771
i'll bet that sounds awesome. I had a class D amp stolen awhile back so I hooked my two channel A/B amp to my subs and it sounded better.
Username: Suleman36
Maryland U.S.A.
Post Number: 3355
Yeah man, class A/B is the way to go if you want the cleanest sound for music. Altough some of the new class D amps from like JL and Arc Audio and Zapco and a few others are extremely clean and not audible at all. Cant tell the differance. Overall i prefer class A/B but class D amps are good for there efficiancy and more forgiving with the Cars Electrical System.
Username: Jonathan_f
GA USA
Post Number: 5805
That Orion 2250SX is a better built amp any listed on this thread. That includes anything RF has ever built, old or new.
Username: Suleman36
Maryland U.S.A.
Post Number: 3358
Its also twice the size and weight. Not my preferance overall.
Username: Lil_jon
Post Number: 351
nice amp mo i got that 1 its chrome u gonna love that thing mine gets hot as hell tho touchd it by accident can hear the skin burn! mayb because its chrome????????
Username: Suleman36
Maryland U.S.A.
Post Number: 3360
What impedence do you have it running at ?
Its best to run the 800a2 at 4 ohm so that it runs cooler. Also make sure you install it someplace with enough space for the amp to get ventilation.
