TV Tuner Hardware for my Dell Dimension 4550
Username: Til23
I'd like to buy the hardware for setting up my desktop w/ a TV Tuner...any suggestions , I usually get my hardware from Newegg, and they've been great....also, how do you access the TV / Cable channels? Is there some kind of remote that I can get too or what??? Thanks..
Username: Outlaw16511
Erie , Pennsylvania US
Post Number: 11
Try Tigerdirect.com for the hardware and if you have Windows Media Center on your computer you'll be able to access your cable channels by setting up a connection to the cable box.
Need to Register?
Forgot Password?
Enable HTML code in message
