Poor picture
Username: John_in_japan
Hi Guys
I recently bought a 50inch Pioneer Plasma.
I also have a satellite dish but the picture is not very clear. Its not the reception and Im using an s-video cable to try and get a better picture.
I noticed another form of output on the back (1st photo) However, Im not sure what its used for, does anyone know?
Also, the dvd and PS2 and the picture isnt that crash hot either.
Whats the best way to hook them up?
Ive taken some photos
First pic is the dvd
Second is the satellite box
Third is the tuner box for the plasma
http://photos.yahoo.com/jlstyles
Username: Bill984
Post Number: 131
that is probably the hdmi connection for a cable/satellite box. i use component video cables on my pioneer.
The Japanese writing on the back of the satellite box says "data out". Would that be HDMI?
Username: Xdrummer03
Tenessee
Post Number: 290
If you have DirecTV get the HD box,there free right now.Use the HDMI there.Use component on your DVD and put it on progressive scan.If the picture on the DVD is not good enough then you might wanna check out a upconvert.
Username: Ehdmi
Post Number: 7
Those connections on the back if I had to guess are HDMI outputs. On HD channels you should/would get a better reception. Hope this helps!
Keith
Http://www.eHDMI.comUpload
