-->Amp Wiring <--
Username: Kicker_guy12
I was just wondering which wiring would you recomend for the rockford fosgate p6002 i was thinking of grabbing an 8-gauge wiring kit off ebay probably somthing like this one http://cgi.ebay.ca/FULL-8-GAUGE-1800-WAT-AMPLIFIER-WIRING-INSTALLATION-KIT_W0QQi temZ5875883820QQcategoryZ71529QQrdZ1QQcmdZViewItem
And someone said an 80 amp fuse ?
anyways some fedback would help
Username: Dustin3
Tigard, Or U.S.
Post Number: 552
i wouldnt. 8 guage i too small for a power wire, for my 800 watts, i use a 4 guage power wire
Thanks for the advice any other opinions ?
Username: Tjmutlow
Post Number: 1657
your better off with 4guage for if you want to add a 2nd amp(4channel0 or go with a bigge amp later in the future...
Username: Fiber
Post Number: 39
just get 4 guage or 2 guage wire and get a piece that you can plug the 4 or 2 guage into and it splits into 4 slots for 8 guage wire i forget the name for the piece but i have one and it's good if you want to add more amps in the future.
Most amp kits on ebay have the piece in them and if not there cheap by there self.
what about the fuse?
Username: Tjmutlow
Post Number: 1668
80 amp glass is fine
Post Number: 7
so 4 guage wiring and an 80 amp fuse...
Username: Rovin
Trinidad & T...
Post Number: 6658
use this guide
http://www.the12volt.com/info/recwirsz.asp
Post Number: 8
thanks
