I have a pansat 2700a. I am using bin 145 and watch Bev sat. I change the time to my location, but still get no info on the EPG. Please help anyone. thanks. Nickey
Network_id (nid) showing a network to broadcast the program; Transport Stream_id (tid) showing a physical channel for the program; Service_id (sid) showing a logical channel for the program; and Event_id (eid) that identifies the program within the channel for the program. This combination of the identifiers is the aforementioned program ID information, and the term "program ID information" is hereafter used to represent this combination.
@nickey ,check it out ,date and time...Somehow, once a week my receiver change it years, 2006 to 2056 ,then autoroll stop working too , not just epg...
Thanks Nickey, I am ok,how are you? I hope you ok and you got wide open TV. By mistake I got CD,from e-bay,for dreambox...(all info...eg..how to....reprogram,how to set up dish ,which lnb to install..),even there is program to open BIN file with full instruction and foto how to correct autoroll and where to write new key and ....,it cost me 19.99$,but it's realy very very usefull info.So I wanna get the same one for Pansat.In 3 weeks I think I'll get it. Thats my story.
I am at dsstester and dscommunity already helping with the new keys today and the autoroll fix..U will all be without TV tonight...I do NOT support thissite if it does NOT support me!
@nickey, You have to be able to use channel master in order to change the the NIDs and TIDs. Mike has already explained to you what's the NID and TID. Find the channel master software, install it, then download your scanned list from your STB. Open the list you just scanned, and bulk change your NIDs. Your TIDs should be good, at least mine were correct on my list. Finally save the changes to your list, then upload the saved list back to your STB. Pluck your receiver turn on, and you should have a good epg if your timezone and date are correct.
