Kicker L7's
Username: Moheevi
Post Number: 41
How much better are the kicker L7's compared to the Kicker L5's???
Username: B101
Queen City, NC USA
Post Number: 1842
20X better!
Username: Sw9152
Post Number: 146
i was wondering the same thing. anyone have a more detailed answer?
Username: Nissankicker
Grambling, LA USA
Post Number: 69
KICKER L5 -------------
MAX WATTAGE: 1200
RMS WATTAGE: 600
SENSITIVITY: (DB) 87.9
FRE. RESPONSE: 20-100K
___________________________
KICKER L7--------------
MAX WATTAGE: 1500
RMS WATTAGE: 750
SENSITIVITY: (DB) 87.4
* GET'S TREMENDOUSLY LOUDER THAN THE L5 *
____________________________
Username: Devastation101
Post Number: 31
The S15L5s are 750/1500, and S15L7s are 1000/2000. I mean, of course there's a 150 watt difference, but both SPL are very good. The new CVXs hit the same as the L7s but sound 10x better, SQ. Honestly though, between the L5 and L7, it's not a whole world of a difference!
Grambling, LA USA
Post Number: 70
I gave you the 12" specs! ... Dontrell gave you the 15" specs... They might sound bigger in SQ * 1 cause they are circle * ... But they don't put out as much bass, and they surely don't get louder than the L7...
