As the most of you said ( Kicker&JL )
Username: Night_mirage
AmmanJordan
Post Number: 186
in Better than JL post .
alot of you said kicker amplifiers is very good .
but sub's not that much .
so what do you think > one 12W6 or two 10"cvx . wire on sx1250.1 amp
Username: Goatin
U.S.A
Post Number: 560
Get 2 12W6 and that amp. or if you dont want 2 maybe a smaller amp if you are on a budget.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 766
the comparison i don't think is fair. i would rather have two tens than one twelve. i think. or maybe. hmm.....
Username: Blainew
Post Number: 1090
just get the two kickers as u decided a while ago
they will be able to handle the power and it will be not as expensive
AmmanJordan
Post Number: 194
Thanks all of you >
Blaine okay i decided but all of you says kicker sub's is not that much ..
