Turntable Technics SL-5
Username: Stefn
Hi,
Bought a Technics SL-5. It is not spinning.
What could be the problem?
Thanks,
Stefan
Username: Mofoknows
Post Number: 7
Busted, maybe? Too many possibilities.
Username: Stefn
As a start maybe I should check if there is power on DC motor. I don't know if there is connection between upper cover (sensors, which enable the spinning the motor) and spinning the motor in the main plate. Definitely there is no belt, right?
