Please tell me you didnt just post with Zapco, and Hifonics asking for a comparison?
What's your budget? Is your budget a couple hundred dollars, or a couple thousand?
HiFonics are good budget amps, seems to be the consensus that they put out about 70%-80% of their rated power, at 14.4 volts. However - beware, Hifonics drop EXTREMELY sharply as the voltage lowers.. (like a HiFonics 1500 puts out 1394 at 14.4 volts, and at 13 volts is tested at below 1000 watts.)
Zapco - if you can afford Zapco - honestly - get Zapco. You wont be sad. (unless you pimped your girlfriend to do it.. and then - you still will probably be pleased.)
That is so true Seth. For budget wise Hifonics isn't that bad, but if you have the money out of those zapco will put a smile on your face.
