Username: The_don Post Number: 1 Registered: Mar-06
Wednesday, March 08, 2006 - 15:20 GMT i have the option of buyin either a pansat 2700 or 3500 but i want to know which one is newer and better
Username: Leew Ketchikan,
ALASKA
Post Number: 234 Registered: Jan-06
Wednesday, March 08, 2006 - 23:52 GMT 3500 is newer=better.
Username: Lklives Post Number: 1235 Registered: Jan-06
Thursday, March 09, 2006 - 00:23 GMT 3500SD is newer and has the card to use in lieu of cable...it has BOTH cable and card..its better
Username: The_don Post Number: 2 Registered: Mar-06
Thursday, March 09, 2006 - 01:48 GMT i bought the 3500sd, brand new for 180, i have a question though, wats the point of a card, wats it do, and wats the cable. sry i'm new in this
Username: Mzakcat Post Number: 12 Registered: Aug-05
Thursday, March 09, 2006 - 03:18 GMT well the don WHY DID YOU BUY the 3500sd wats the reason?????
Username: The_don Post Number: 3 Registered: Mar-06
Thursday, March 09, 2006 - 03:30 GMT to get TV, lol i'm also wondering if there is a step by step posted somewhere for newbies, to program it or w/e for ppv and all that like dishnetwork, i never used fta, its my first experience, but i used dtv, and dishnet
Username: Sva Post Number: 2 Registered: Mar-06
Thursday, March 16, 2006 - 06:58 GMT I've read a couple articles talking about putting dumbie satellites in the sat list, is this always necessary or necessary on a 3500SD?
ALASKA
Post Number: 351 Registered: Jan-06
Thursday, March 16, 2006 - 12:01 GMT How to set up...for newbies,use this link : http://forums.dss *tester.com/vbb/showthread.php?t=39491
ALASKA
Post Number: 352 Registered: Jan-06
Thursday, March 16, 2006 - 12:04 GMT dont forget ,to remove {*} in d s s t e s t e r
ALASKA
Post Number: 353 Registered: Jan-06
Thursday, March 16, 2006 - 12:11 GMT For 50 CAL......... I got 3500sd,and I never renamed or put dumm..sat. just flashed with Bin, blind scan and wait till autoroll getting the key. That is all.
Username: Sva Post Number: 3 Registered: Mar-06
Thursday, March 16, 2006 - 16:02 GMT Thanks M W Lee, I just wanted to clarify.
