Kicker s18 10,000 watts
Username: Seatlion
Hey guys
I want to buy the KICKER S18 but I don't know which amplifier to buy or what I should buy to make it work the right way.
Any suggestion will be appreciated thanks
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1518
Get two of those Kicker 2500.1's and connect one to each VC.
Username: Nissankicker
Grambling, LA USA
Post Number: 24
Yeah.. That's probably the best thing to do!...
ORRRR!!!!
You can get cheap and buy
(4) Boss Ripper-D 3000Watt Amps and put 2 on each voice coil... and Bridge all 4 together... you'll get about (2200)*(4) 8800 watts ( 8200 rms )
Username: Homegrowncam
Watauga, TX United States
Post Number: 244
Yeah just go with the kickers and dont get anything boss!
Grambling, LA USA
Post Number: 38
Hey!.. What's wrong w/ Boss?? I have 2 Boss Ripper Class D 3000 Watt amps... And they are the sh!t... and they do push what they say " 2100-2200 " rms
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 483
I will believe it when I either see one benched or see a birth sheet. Period. BTW what are those amps fused at??
Grambling, LA USA
Post Number: 43
Depending on which Series/Model you get.. Mine is fused @ 4x30amp ... If I come to Greenboro, NC this summer... I'll give you a holla!
Username: B101
Queen City, NC USA
Post Number: 1759
my 1000d amp had more fuses thant that, 40X4= 160a!
if u want 10,000 watts totatl?? I highly doubt that been a RMS value, so if u want easy 5000rms, just get 2 orion 2500ds
Username: B101
Queen City, NC USA
Post Number: 1760
dj tucker u in GBORO?? I was up in the TRIAD 2 weeks ago.... get @ me...
Post Number: 249
HAHA what are your BOSS amps pushing?
Username: B101
Queen City, NC USA
Post Number: 1767
my amp has NO fuse, lol... it can draw over 200 amps at full tilt...
it needs to be fused within 12ft with a external ANL fuse............
Grambling, LA USA
Post Number: 46
HAHA!... That's awesome B ... I have family in Greensboro & Fayetteville! I should be there this coming up summer!
Cam - My boss amp pushs 2100 or 2200 rms But since I have 2, and they are dataly connected and bridged, I have a Max 6000 watts, w/ 4600 rms b/c it drops to .5 ohm
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 477
My amp also has no fuse, has to be externally fused as well.
Mine will draw 120a at full tilt but is 2000rms, Dark Blue by Helix.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2420
DJ,
boss amps wont put out anywhere near their rated power...i have owned and installed quite a few.
i had a boss "2800w" amp once and i swapped it out for a jbl bp600.1...the JBL killed the boss on every level.
also...one way to kinda guess-tamate how much an amp will put out is to do multiply fuse rating by input volage.
4*30= 120
120A * 14.4V = 1728w (and that is if the amp is 100% efficient...and nothing is 100% efficient)
this would be a better guess:
1728 * 80% = 1382.4w
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 485
Thats interesting. I have a kicker kx600.1, It has two 30 amp fuse. It benches around 725 rms @ 2 ohms. So I cant see how your amplifier is able to put out 2200 rms @ 2 ohms(three times mine) with only twice the fuseing. Doesnt seem mathematicly sound to me. Peace
Grambling, LA USA
Post Number: 53
No.. It's 2200 @ 1ohm ...
I own 4 JBL amps
JBL1201.1
JBL600.1
JBL300.1
JBL80.1
They are UNDERRATED.. The 1201.1 says 1374 rms it's really 1700+ rms...
Username: Jeffless600
Post Number: 40
http://cgi.ebay.com/ebaymotors/HIFONICS-BXI2006D-BRUTUS-2000w-MONO-CAR-AMPLIFIER -AMP_W0QQcmdZViewItemQQcategoryZ38638QQitemZ8046982642QQrdZ1
get 2
Post Number: 251
What subs are you powering with those bosses?
Username: Sw9152
Post Number: 131
they are kind of difficult to find, but the older style(big and black) directed 2400d is comparable to the orion 2500d.
Grambling, LA USA
Post Number: 55
I'm powering 2 S12L7s ... Soon to be 3...
SW9152 ... That is a monster amp!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 186
mike where did you get that amp?
