Components
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 755
I was thinking about the diamond audio S600A's, but I'm open to suggestions. How are JL's components?
Username: Alteraudiousa
Concord
Post Number: 459
which series JL, ZR series, they're quite good. CDT is always a good choice and I'm gauging interest on the amp/speaker combo for a full CDT set. Also depending on budget look into Dyna too.
Username: Jonathan_f
GA USA
Post Number: 5797
What price range are you talking about? The XRs are excellent for the money. ZRs are nice, but IMO not the best in their price range.
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 695
I have a pair of the Jl XR components and they are a really nice set of comps. they are very clean sounding and the tweeters are not harsh at all. it depends on your budget but i would highly recommend the JL XR's
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 756
i want to get two pair so no more than $200. Thanks alot.
