Gold Member Username: B101Queen City, NC USA Post Number: 1666 Registered: Sep-05 | Product Dimensions RE Series 8" Mounting Depth - 4" Mounting Hole Diameter - 7.125" Overall Diameter- 8.25" Bolt Hole Circle - 7.75" Motor Width - 4.875" Motor Depth - 1.5" Basket Depth - 2.5" Displacement - .07 cu. ft. Weight - 6 lbs. 10" Mounting Depth - 5" Mounting Hole Diameter - 9.125" Overall Diameter - 10.125" Bolt Hole Circle - 9.75" Motor Width - 4.875" Motor Depth - 1.5" Basket Depth - 3.5" Displacement - .09 cu. ft. Weight - 6.5 lbs. 12" Mounting Depth - 5.5" Mounting Hole Diameter - 10.875" Overall Diameter - 12.25" Bolt Hole Circle - 11.75" Motor Width - 4.875" Motor Depth - 1.5" Basket Depth - 4" Displacement - .10 cu. ft. Weight - 7 lbs. SR Series 10" Mounting Depth - Mounting Hole Diameter - Overall Diameter - Bolt Hole Circle - Motor Width - Motor Depth - Basket Depth - Displacement - Weight - 12" Mounting Depth - Mounting Hole Diameter - ...............................................FULL SPECS COMING SOON! Overall Diameter - Bolt Hole Circle - Motor Width - Motor Depth - Basket Depth - Displacement - Weight - 15" Mounting Depth - Mounting Hole Diameter - Overall Diameter - Bolt Hole Circle - Motor Width - Motor Depth - Basket Depth - Displacement - Weight - SE Series 10" Mounting Depth - 6" Mounting Hole Diameter - 9.25" Overall Diameter - 11" Bolt Hole Circle - 10.125" Motor Width - 6.25" Motor Depth - 3.25" Basket Depth - 2.75" Displacement - .14 cu. ft. Weight - 20 lbs. 12" Mounting Depth - 6.5" Mounting Hole Diameter - 11" Overall Diameter - 12.5" Bolt Hole Circle - 11.75" Motor Width - 6.25" Motor Depth - 3.25" Basket Depth - 3.25" Displacement - .15 cu. ft. Weight - 21 lbs. 15" Mounting Depth - 7.75" Mounting Hole Diameter - 14" Overall Diameter - 15.5" Bolt Hole Circle - 14.75" Motor Width - 6.25" Motor Depth - 3.25" Basket Depth - 4.5" Displacement - .17 cu. ft. Weight - 23 lbs. SX Series 10" Mounting Depth - 6" Mounting Hole Diameter - 9.25" Overall Diameter - 11" Bolt Hole Circle - 10.125" Motor Width - 6.5" Motor Depth - 3.25" Basket Depth - 2.75" Displacement - .15 cu. ft. Weight - 23 lbs. 12" Mounting Depth - 6.5" Mounting Hole Diameter - 11" Overall Diameter - 12.5" Bolt Hole Circle - 11.75" Motor Width - 6.5" Motor Depth - 3.25" Basket Depth - 3.25" Displacement - .16 cu. ft. Weight - 24 lbs. 15" Mounting Depth - 7.75" Mounting Hole Diameter - 14" Overall Diameter - 15.5" Bolt Hole Circle - 14.75" Motor Width - 6.5" Motor Depth - 3.25" Basket Depth - 4.5" Displacement - .18 cu. ft. Weight - 27 lbs. 18" Mounting Depth - 9.5" Mounting Hole Diameter - 16.75" Overall Diameter - 18.5" Bolt Hole Circle - 17.5" Motor Width - 6.5" Motor Depth - 3.25" Basket Depth - 6.25" Displacement - .22 cu. ft. Weight - 28 lbs. MX Series 12" Mounting Depth - 10.25" Mounting Hole Diameter - 11.375" Overall Diameter - 13" Bolt Hole Circle - 12.25" Motor Width - 8.5" Motor Depth - 2.5" Basket Depth - 7.75" Displacement - .19 cu. ft. Weight - 33 lbs. 15" Mounting Depth - 11" Mounting Hole Diameter - 14.625" Overall Diameter - 16" Bolt Hole Circle - 15.25" Motor Width - 8.5" Motor Depth - 2.5" Basket Depth - 8.5" Displacement - .22 cu. ft. Weight - 36 lbs. 18" Mounting Depth - 12.25" Mounting Hole Diameter - 17.375" Overall Diameter - 19" Bolt Hole Circle - 18.25" Motor Width - 8.5" Motor Depth - 2.5" Basket Depth - 9.75" Displacement - .25 cu. ft. Weight - 38 lbs. MT Series 10" Mounting Depth - 7.25" Mounting Hole Diameter - 9.25" Overall Diameter - 11" Bolt Hole Circle - 10.125" Motor Width - 9" Motor Depth - 4.5" Basket Depth - 2.75" Displacement - .18 cu. ft. Weight - 57 lbs. 12" Mounting Depth - 8" Mounting Hole Diameter - 11" Overall Diameter - 12.5" Bolt Hole Circle - 11.75" Motor Width - 9" Motor Depth - 4.5" Basket Depth - 3.25" Displacement - .19 cu. ft. Weight - 58 lbs. 15" Mounting Depth - 9" Mounting Hole Diameter - 14" Overall Diameter - 15.5" Bolt Hole Circle - 14.75" Motor Width - 9" Motor Depth - 4.5" Basket Depth - 4.5" Displacement - .21 cu. ft. Weight - 61 lbs. 18" Mounting Depth - 10.75" Mounting Hole Diameter - 16.75" Overall Diameter - 18.5" Bolt Hole Circle - 17.5" Motor Width - 9" Motor Depth - 4.5" Basket Depth - 6.25" Displacement - .25 cu. ft. Weight - 62 lbs. XXX Series 12" Mounting Depth - 12.75" Mounting Hole Diameter - 11.375" Overall Diameter - 13" Bolt Hole Circle - 12.25" Motor Width -10.5" Motor Depth - 5" Basket Depth - 7.75" Displacement - .24 cu. ft. Weight - 72 lbs. 15" Mounting Depth - 13.5" Mounting Hole Diameter - 14.625" Overall Diameter - 16" Bolt Hole Circle - 15.25" Motor Width - 10.5" Motor Depth - 5" Basket Depth - 8.5" Displacement - .27 cu. ft. Weight - 76 lbs. 18" Mounting Depth - 14.75" Mounting Hole Diameter - 17.375" Overall Diameter - 19" Bolt Hole Circle - 18.25" Motor Width - 10.5" Motor Depth - 5" Basket Depth - 9.75" Displacement - .30 cu. ft. Weight - 78 lbs. T/S Parameters RE Series 8" Electrical Q Value -Qes: 0.38 Mechanical Q Value -Qms: 4.21 Total Speaker Q Value -Qts: 0.34 Free Air Resonance -Fs: 22.8 Hz Equivalent Compliance -Vas: 27.1 liters One-Way, Linear Excursion -Xmax: 12 mm Efficiency - SPL 1W/1m: 81.2 dB SPL Effective Piston Area -Sd: 195 cm^2 DC Resistance -Re: 3.2 ohm per coil Nominal Impedance -Znom: Dual 4 ohm Thermal Power Handling -Pe: 175 W Force Factor -Bl: 15.4 10" Electrical Q Value -Qes: 0.39 Mechanical Q Value -Qms: 4.37 Total Speaker Q Value -Qts: 0.36 Free Air Resonance -Fs: 21.5 Hz Equivalent Compliance -Vas: 75.6 liters One-Way, Linear Excursion -Xmax: 12 mm Efficiency - SPL 1W/1m: 84.7 dB SPL Effective Piston Area -Sd: 322 cm^2 DC Resistance -Re: 3.2 ohm per coil Nominal Impedance -Znom: Dual 4 ohm Thermal Power Handling -Pe: 175 W Force Factor -Bl: 15.4 12" Electrical Q Value -Qes: 0.42 Mechanical Q Value -Qms: 4.27 Total Speaker Q Value -Qts: 0.38 Free Air Resonance -Fs: 20.0 Hz Equivalent Compliance -Vas: 182 liters One-Way, Linear Excursion -Xmax: 12 mm Efficiency - SPL 1W/1m: 87.3 dB SPL Effective Piston Area -Sd: 500 cm^2 DC Resistance -Re: 3.2 ohm per coil Nominal Impedance -Znom: Dual 4 ohm Thermal Power Handling -Pe: 175 W Force Factor -Bl: 15.4 SR Series 10" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 18 mm Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 310 cm^2 DC Resistance -Re: 1.8 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 300 W 12" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 18 mm ...............................................FULL SPECS COMING SOON! Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 480 cm^2 DC Resistance -Re: 1.8 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 300 W 15" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 18 mm Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 1.8 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 300 W SE Series 10" Electrical Q Value -Qes: .46 Mechanical Q Value -Qms: 4.4 Total Speaker Q Value -Qts: .42 Free Air Resonance -Fs: 26.6 Hz Equivalent Compliance -Vas: 31 liters One-Way, Linear Excursion -Xmax: 18 mm Efficiency - SPL 1W/1m: 83.2 dB SPL Effective Piston Area -Sd: 310 cm^2 DC Resistance -Re: 2.8 ohm Nominal Impedance -Znom: Dual 4 ohm Thermal Power Handling -Pe: 600 W Force Factor -Bl: 17.7 12" Electrical Q Value -Qes: .49 Mechanical Q Value -Qms: 4.5 Total Speaker Q Value -Qts: .44 Free Air Resonance -Fs: 25.1 Hz Equivalent Compliance -Vas: 72.9 liters One-Way, Linear Excursion -Xmax: 18 mm Efficiency - SPL 1W/1m: 86.1 dB SPL Effective Piston Area -Sd: 480 cm^2 DC Resistance -Re: 2.8 ohm Nominal Impedance -Znom: Dual 4 ohm Thermal Power Handling -Pe: 600 W Force Factor -Bl: 17.7 15" Electrical Q Value -Qes: .55 Mechanical Q Value -Qms: 4.3 Total Speaker Q Value -Qts: .49 Free Air Resonance -Fs: 22 Hz Equivalent Compliance -Vas: 209 liters One-Way, Linear Excursion -Xmax: 18 mm Efficiency - SPL 1W/1m: 88 dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 2.8 ohm Nominal Impedance -Znom: Dual 4 ohm Thermal Power Handling -Pe: 600 W Force Factor -Bl: 17.7 SX Series 10" Electrical Q Value -Qes: .29 Mechanical Q Value -Qms: 4.3 Total Speaker Q Value -Qts: .27 Free Air Resonance -Fs: 30.7 Hz Equivalent Compliance -Vas: 21.8 liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency - SPL 1W/1m: 85.2 dB SPL Effective Piston Area -Sd: 310 cm^2 DC Resistance -Re: 1.9 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1000 W Force Factor -Bl: 21 12" Electrical Q Value -Qes: .32 Mechanical Q Value -Qms: 4.4 Total Speaker Q Value -Qts: .30 Free Air Resonance -Fs: 30.6 Hz Equivalent Compliance -Vas: 47.6 liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency - SPL 1W/1m: 88.1 dB SPL Effective Piston Area -Sd: 410 cm^2 DC Resistance -Re: 1.9 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1000 W Force Factor -Bl: 21 15" Electrical Q Value -Qes: .38 Mechanical Q Value -Qms: 4.7 Total Speaker Q Value -Qts: .38 Free Air Resonance -Fs: 27.8 Hz Equivalent Compliance -Vas: 126.3 liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency - SPL 1W/1m: 90.4 dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 1.9 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1000 W Force Factor -Bl: 21 18" Electrical Q Value -Qes: .53 Mechanical Q Value -Qms: 6.1 Total Speaker Q Value -Qts: .48 Free Air Resonance -Fs: 33.2 Hz Equivalent Compliance -Vas: 159 liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency - SPL 1W/1m: 92.7 dB SPL Effective Piston Area -Sd: 1210 cm^2 DC Resistance -Re: 1.9 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1000 W Force Factor -Bl: 21 MX Series 12" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 480 cm^2 DC Resistance -Re: 1.4 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1500 W 15" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 22 mm ...............................................FULL SPECS COMING SOON! Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 1.4 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1500 W 18" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 22 mm Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 1210 cm^2 DC Resistance -Re: 1.4 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 1500 W XXX Series 12" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 54 mm Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 480 cm^2 DC Resistance -Re: 2.0 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 2000 W 15" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 54 mm ...............................................FULL SPECS COMING SOON! Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 2.0 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 2000 W 18" Electrical Q Value -Qes: Mechanical Q Value -Qms: Total Speaker Q Value -Qts: Free Air Resonance -Fs: Hz Equivalent Compliance -Vas: liters One-Way, Linear Excursion -Xmax: 54 mm Efficiency - SPL 1W/1m: dB SPL Effective Piston Area -Sd: 1210 cm^2 DC Resistance -Re: 2.0 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 2000 W |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1940 Registered: Dec-05 | about time we got some specs on the xxx and mx |
Gold Member Username: B101Queen City, NC USA Post Number: 1668 Registered: Sep-05 | I knew a few of u guys needed this... Its from David @ RE! |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1942 Registered: Dec-05 | the mx handles 1500wrms ... little expensive but it looks sexy |
Silver Member Username: Baseball1187Columbia, SC Post Number: 623 Registered: Dec-04 | is that wrong for MX? only 22mm xmax? |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 106 Registered: Feb-06 | the xxx 76 pounds |
Gold Member Username: Mikechec9Post Number: 2245 Registered: May-05 | It's easier to just post the link (for book marks) http://forum.carstereos.org/showthread.php?t=58992 Also, a good reference angle of the XXX 12" http://i22.photobucket.com/albums/b301/mikechec9/xxxsub.jpg |
Gold Member Username: Mikechec9Post Number: 2246 Registered: May-05 | That's why it's so heavy (and in many cases impractical, imo). |
Gold Member Username: BlainewPost Number: 1053 Registered: Nov-05 | wow i had no idea the XXX looked like that |
Gold Member Username: BlainewPost Number: 1054 Registered: Nov-05 | i dont think thats an xxx.... heres one from the RE site |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2395 Registered: Mar-04 | blaine...that pic you posted is the old XBL^2 XXX. the one mikechec9 posted is the new split-coil XXX. |
Gold Member Username: BlainewPost Number: 1056 Registered: Nov-05 | oooooooo i see sorry haha |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2397 Registered: Mar-04 | i only see one thing i dont like about the new XXX...i kinda wish RE would have went w/ a high-roll surround. (more Sd) |
Gold Member Username: Mikechec9Post Number: 2248 Registered: May-05 | "i only see one thing i dont like about the new XXX...i kinda wish RE would have went w/ a high-roll surround. (more Sd)" I'm sure they considered it. But then you would be faced with "dimple noise" associated with ID at high excursion. Besides, what the sub lacks in surface area, it makes up for in raw excursion. I forgot the actual number but it wasn't in mm. It was listed in inches |
Gold Member Username: BlainewPost Number: 1057 Registered: Nov-05 | how much $ is that bad boy |
Gold Member Username: BlainewPost Number: 1058 Registered: Nov-05 | and.....what other new stuff did RE come out with besides the XXX |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 432 Registered: Jan-06 | Actually the photobucket picture is the NEW XXX. I have a brochure in my hands and that is what it shows, and why it is soooo heavy! It is also the reason they are going to be $660 for the 15". I can't wait for them to get here!! I wished someone would hurry the FVKK UPP before I die with anticipation, lol...Polo.. |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 589 Registered: Aug-04 | the excursion of the xxx in inches is 4.5" peak to peak i believe. |
Silver Member Username: RedlinerWilmington, Ma Post Number: 996 Registered: Jun-05 | does anyone know how much the xxx will cost for the 12" |
Silver Member Username: Dpaw20FL USA Post Number: 346 Registered: Mar-05 | one day, when i make enough money and have a car that can fit it... im going to buy a 15" XXX and put it in the perfect box for it and get the perfect amp for it wowwww i cant wait till i can get away from the gayness of low budget and space limitations |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 590 Registered: Aug-04 | heres the prices for the XXX's shipped to Louisiana, it may vary a little for other places but only about 10 dollars at most. XXX 12 $630 shipped XXX 15 $670 shipped XXX 18 $710 shipped 12's will be available Thurs March 16th, ready to ship. 15's will be about another 6 weeks before they are ready. and 18 will be about another 9 weeks. same goes for all the MX and SR subs, another 6-9 weeks before they will be available. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 446 Registered: Jan-06 | NO WONDER THEY WEREN'T ANSWERING TODAY, LOL. They knew I was calling! I want my XXX 15 and I want it NOW, MUUAAHHHHHHHHHHHHH... Too bad I don't have room for a pair of them becasue these have to fit first, lol.. |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 592 Registered: Aug-04 | yeah i got threw on the first try today lol. i got specs on the 4 ch amp they have too its 100w X 4 @ 2 ohms. it was like 350 shipped to LA. |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 593 Registered: Aug-04 | WTF, BUMP UP! |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1013 Registered: Jun-05 | 630 shipped looks like i might be getting one of them in a little while cannot wait |
Bronze Member Username: PalanzaPost Number: 66 Registered: Dec-05 | I'd need a new alternator to get anything more than my 2 infi subs i have now (( Too much $$$$ to invest lol ahh |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1016 Registered: Jun-05 | by the way guys are these going to be pure spl or are they going to be like the last ones jw |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1017 Registered: Jun-05 | bump since it didnt |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2413 Registered: Mar-04 | the new XXX's are supposed to be the ultimate SQL sub. (JL w7, eat my dust sort of thing) |
Silver Member Username: Goose5714Post Number: 346 Registered: Feb-06 | How about the MX??? IS it spl or sq or what???? I like the addition of the sr there was a pretty big gap there without it...although it doesn't benefit me...That new xxx is amazing...whenever i get my new car its gonna be a tough decision between that, a w7, and a mag ...oh well thats a long ways off. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 448 Registered: Jan-06 | He Marshall, how well do think it would do in that enclosure of mine that has the sx in? Polo. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1021 Registered: Jun-05 | thanks alot marshall thats what i figured but i just heard it might be a spl woofer so i just wanted to make sure |
Gold Member Username: BlainewPost Number: 1077 Registered: Nov-05 | the new XXX? |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1039 Registered: Jun-05 | aww man those pics just make me want it even more lol |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 454 Registered: Jan-06 | I think that is the new MX sub, going by the new brochure but the magnet is a little different. this is the new XXX and shows the exact same thing in the Brochure, that is why the beast is sooo heavy. Polo. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1948 Registered: Dec-05 | holy hell that thing is a beast |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1043 Registered: Jun-05 | lol they look so close to one another i think polo is correct about it though good eye polo does anyone have anymore pics of the XXX |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 457 Registered: Jan-06 | The only problem I have with it is if its going to to be 76lbs, how are you supposed to mount it, especially sideways? Have any idea the amount of sideways force it would have on them screws not to mention the material would have to be at least 1 1/2" thick. Polo.. |
Silver Member Username: NemenPost Number: 538 Registered: Dec-05 | the top one is not a mx the MX looks way different and its suposed to have neo magnets |
Silver Member Username: NemenPost Number: 539 Registered: Dec-05 | it dindt bump! |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 597 Registered: Aug-04 | yeah nemen is right the top pic is not the MX, both pics are pics of the XXX the mx is smaller the first pic where the sub has a grey basket and is being compared to the previous XXX model is the prototype XXX before they renewed the look. the new XXX out for production and sale does not have the RE logo on the dust cap it has the XXX logo like the previous sub. the pic that polo posted is the new XXX, the final product. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 459 Registered: Jan-06 | Nemen there is only two subs with those baskets, the XXX and the MX. I did mention it looked like the MX but the magnet was a little different. It is in no way the new XXX but maybe a proto of the mx without the neo's? Hard to tell unless it was laid on its side. I do know the second one is the new XXX, Polo.. |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 599 Registered: Aug-04 | BUMP DAMMIT!! |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 600 Registered: Aug-04 | oops |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 601 Registered: Aug-04 | have none of yall seen the MX SR and new XXX subs at the SEMA show?? |
Silver Member Username: NemenPost Number: 540 Registered: Dec-05 | someone had a picture of the MX a while backthat was on tempro does anyone have it. |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 602 Registered: Aug-04 | someone had pics of all the subs at the SEMA show and posted them on here. but i havent the slightest clue where nor the enthusiasm to go find them. |
Silver Member Username: NemenPost Number: 545 Registered: Dec-05 | so im guessing this is the second one polo posted also |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 460 Registered: Jan-06 | LAZY B@STARDS!!!! LOL..Polo Here's the new XXX And the new MX |
Silver Member Username: PelonaAlabama Post Number: 925 Registered: Dec-05 | daaaaammmmmnnnnn!!! those things look crazy!!!!! |
Silver Member Username: NemenPost Number: 548 Registered: Dec-05 | lol polo I was trying to google but i couldnt find sh!t. I think i like the xxx in silver instead of that black but who cares cause youre not gonna see it its gonna be in the box lol. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 461 Registered: Jan-06 | XXX frontal |
Silver Member Username: NemenPost Number: 549 Registered: Dec-05 | D2mn that surround almost looks like a bike tube lol Polo then what sub is that the one that has RE on the front is it still the xx xjust with the RE front? |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 462 Registered: Jan-06 | Hey Nemen, that is the front of the MX sub! Here is the real copy of that picture...Polo |
Silver Member Username: NemenPost Number: 551 Registered: Dec-05 | oh i see i guess i had the bootleg pic lol |
Silver Member Username: NemenPost Number: 552 Registered: Dec-05 | Bump D@mn it! |
Silver Member Username: PelonaAlabama Post Number: 927 Registered: Dec-05 | u guys are confusing me now.......wich ones the mx and wich ones the xxx? |
Silver Member Username: NemenPost Number: 555 Registered: Dec-05 | lol the XXX is the one with the chains and the Mx is the one thats on that piece of metal or whatever that is. |
Silver Member Username: PelonaAlabama Post Number: 930 Registered: Dec-05 | i like the mx's basket |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 603 Registered: Aug-04 | i also liked the XXX with the grey basket and the RE logo instead of the XXX logo. but o well, it will still slam. oh yeah and im gettin the 12, prolly ordering thurs or fri. i got my income tax return, just enuff for the sub and some change. |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 470 Registered: Jan-06 | BRING THIS BAD MUTHA FUKKA UP! |
Gold Member Username: RedlinerWilmington, Ma Post Number: 1060 Registered: Jun-05 | holy sh!t that things looks awesome(no not the as$ lol)it will be so hard to make a box for that thing imagine the bracing |
Gold Member Username: B101Queen City, NC USA Post Number: 1771 Registered: Sep-05 | the XXX looks very mean... I must say.. |
Bronze Member Username: BuckshotPost Number: 84 Registered: Nov-05 | which subs are they remodeling just the XXX? or are they doing all of em or a cuple or what? |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 476 Registered: Jan-06 | holy sh!t that things looks awesome(no not the as$ lol)it will be so hard to make a box for that thing imagine the bracing Ya, we know the truth Charlie, lol...Polo.. |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 604 Registered: Aug-04 | anyone want to buy last years model XXX 12?? i have to sell mine to get an altenator. 300 for sub 400 for sub and box : 3 cuft net tuned to ruffly 30-32 hz demensions are 38 wide x 15 deep x 16 tall. |
