JBL GTO or Infinity Reference?
Username: Paogr
AthensGreece
Post Number: 7
I'm between JBL GTO 1202D (300wrms) and Infinity Reference 1240W (300wrms). I saw the specs of two subs and they look similar. Which should i buy? Should i use sealed or ported box and if ported at what Fs tuned?
Thanks.
I have the JBL GTO 75.2 amp (290wrms bridged).
Username: Mikechec9
Post Number: 2249
Infinity will sound better. The GTO is a loose sub with a relatively hollow sound. Not solid or tight.
Username: Nissankicker
Grambling, LA USA
Post Number: 23
Infinity is good, but me, personally, I like JBL subs.. GTO is like he said " a loose sub " BUT! with the right box * Ported * and right freq. * 30-35 * it'll out-do the infinity! I would tell you to get a Probox SuperBass for a single 12 BUT!!!! the JBL is a bigger 12" and you'll need something * Like the rubber part around the kicker to make it possible to screw in! * * the rubber part would sit underneath the jbl while you screw it in! *
Username: Winterfreshpimp
Chisago, MN America
Post Number: 59
i dont know ive always like infinty, moved past them becasue they dont make a strong enough sub 4 me
