New member Username: Mygame5982Houston, Texas Us Post Number: 10 Registered: Jan-06 | My homeboy has two fifthteen inch q power subs hooked to a 2200 watt boss amp and it pounds like hell. I found on the internet two fifthteen q powers for 200 plus 30 for shipping without box. Is this a good deal? If so what amp should i get for it? |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 12 Registered: Jan-06 | By the way they handle 3000 watts max |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5965 Registered: Jul-05 | maxx watts are useless, what are the rms on those subs?? |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 13 Registered: Jan-06 | i dont know chauncey thats all i have. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5967 Registered: Jul-05 | I wouldnt waste my money on something if they didnt tell me everything i need to no about the product.. Whats ur budget |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 14 Registered: Jan-06 | i have 900 but i only wanna spend max 480 on a system. im getting a jvc headunit for 50 so all i need is amp and speakers. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5968 Registered: Jul-05 | subs http://cgi.ebay.com/PAIR-2-NEW-05-KICKER-CVR15-COMP-VR-15-2-ohm-1000-W_W0QQitemZ 5878020981QQcategoryZ58035QQrdZ1QQcmdZViewItem amp http://cgi.ebay.com/Audiobahn-A8000T-800W-MONO-Intake-Series-Amplifier-NEW_W0QQi temZ5877192215QQcategoryZ64571QQrdZ1QQcmdZViewItem |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5969 Registered: Jul-05 | BTW: ur friends amp does not put out 2200 rms, does he have an electrical system upgrade..If not then thats not possible |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5970 Registered: Jul-05 | Plus Boss, sucks, big time |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1431 Registered: Aug-05 | WOOT! That's an A8000T BABY! |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 15 Registered: Jan-06 | if the kickers handle 2000 peak i want at least a amp that puts out 1600 or 1800 watts peak and 1000 or 1200 rms |
Gold Member Username: Iufan4lifeulPost Number: 1007 Registered: May-05 | Peak is WORTHLESS. Don't even look at peak. If something doesn't rate in RMS then don't buy it. Chauncey said it earlier. I guarantee you my Kicker 500 watt setup can beat your friends 2200 watt setup or whatever hands down. |
Silver Member Username: Young_jamesCanada Post Number: 925 Registered: Sep-05 | ^^^I agree with Chauncey and Chris.......Peak don't anything. You must always look at the RMS, and that system chauncey picked out would be way better than your friend's system. Those are great subs and they will get loud with that amp. So stop talking about peak because companies only use that to make their stuff look good. Only worry about the RMS because that's what your going to get. |
Bronze Member Username: Liqdfire3Lee high acres, Florida Post Number: 56 Registered: Sep-05 | does ur friend have the black q power subs? the duluxe series? i have 2 12" q power subs deluxe series subs. they are rated at 600 rms and 1200 max. they pound alright but the sound quality is nothing to my kicker comp vr's that i had recently. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5974 Registered: Jul-05 | A hard head makes for an empty wallet |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1444 Registered: Aug-05 | Or he could by a pair of Assassins!!! I personally think they have better SQ (by far). Also, I bet that the SPLs would rival from what Jonathan has told me... |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 17 Registered: Jan-06 | Yeah they the deluxe series. But about the audibahn amp. Its only 800 watts shouldnt i get more then that, because i wanna get the full watts out the kickers to beat the block up like a punchin bag. |
Bronze Member Username: CtmikeCt. Post Number: 40 Registered: Feb-06 | amp http://cgi.ebay.com/KICKER-KX1200-1-CAR-AUDIO-CLASSD-MONO-SUB-AMP-AMPLIFIER_W0QQ itemZ5876769646QQcategoryZ79829QQrdZ1QQcmdZViewItem 3 of these subs http://ascendantaudio.com/assassin12specs.html little more than your budget but worth it |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 18 Registered: Jan-06 | will this system BEAT? 2 kicker 15 inch comp cvrs and a Kenwood KAC-9152D 1800 watt amp? This is what i really wanted. Do you all agree? |
Bronze Member Username: CtmikeCt. Post Number: 41 Registered: Feb-06 | subs are good, but get a stronger amp. those subs will handle more than what the amp will put out. also, kenwood amps are ok, but they tend to overheat and shut off. |
Bronze Member Username: Mygame5982Houston, Texas Us Post Number: 19 Registered: Jan-06 | oh really? |
Silver Member Username: CadillacdbHouston , TX Post Number: 645 Registered: Aug-05 | the subs are fine but dont buy the kenwood an please stop talking about Max power as if it really matters because RMS is the only thing that matters an with some names such as Legacy Pyramid an sound storm they even lie about the RMS power an thats only a few of the names that will lie about the RMS power,,, you should really listen to Chauncey |
Silver Member Username: CadillacdbHouston , TX Post Number: 646 Registered: Aug-05 | Oh an Just to let you know.. Q Power is Junk an Boss is junk So ur Home Boy is running Junk... Dont give Houston a bad name with all this Talk about Junky Equipment |
Silver Member Username: CadillacdbHouston , TX Post Number: 647 Registered: Aug-05 | If you gonna Roll In H-Town with Bass in ur trunk then do ur self a favor an dont buy junk because Lots of guys around here put thousands an Thousands into there Systems an if your runnin Junk you will have ur as* handed to you if you try to take some ones system on with urs |
Silver Member Username: CadillacdbHouston , TX Post Number: 649 Registered: Aug-05 | The kickers are a good Choice in subs for ur Budget an since you want more power get the Hifonics BX1205D amp to push the subs with but get the 4 ohms DVC version of those kicker Subs an not the 2 ohms DVC version an wire the subs together for 1 ohm mono an hook um up to the amp that setup should be right within ur budget an it will put ur friends Junk to shame but i wouldnt advise getting any more powerful of an amp because anything more an u will definetly have to upgrade ur alternator an add a yellowtop Battery |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6067 Registered: Jul-05 | be careful, wanting more power, u will have to upgrade ur electrical system to handle that much power That is the reason i recomended the 800 amp and not something like 2500watts |
