Why is a low tuned box louder to the ear but not loud on the mic
Username: Jprix82
Post Number: 347
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2390
because you 'feel' lower bass more than you actually 'hear' it. low notes will rattle ya and move a h3ll of alota air :-)
Username: Jprix82
Post Number: 361
So since a low tuned box is louder by ear why do people tune it in the mid 30hz for daily driving?
Username: B101
Queen City, NC USA
Post Number: 1754
low tuned box are for more sound quality, 30-35 is considered low tuned.
why is it louder to your ear? becuase lower frequency gernerate a longer sound wave, so they travel further.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11382
25-35Hz is low tuned.
oyu don't want to tune a ported box below the Fs of the sub itself. You lose any benefit to porting by doing so.
Tuning for SPL falls in the range of 45-60Hz.
Tuning in the 50Hz range will be louder both on a mic and to the ears, but it won't sound good at all.
Tuning in the 25-35Hz range is more musical for a peak response range.
Remember 20Hz is the minimum for hearing.
Anything below 20Hz is below your ability to hear anyway.
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 471
But you can still feel it. : ) I think one of these days I am going to build a ported enclosure for my 15's and tune it to 20 hz(the FS on my drivers is around 18). Just an attempt at the brown note.
Username: Safe_cracker
Chicago, IL US
Post Number: 467
Sound is a compression and decompression (rarification) of electrons in a particular medium, for us it will be air. Every comression/decompression is considered a wave in shape and form unless clipped. The number of waves per second is a measure called Hertz (hz). Lower frequencies are made up of lower hz and such has lower amount of waves. Raising the amount of waves increases the frequency/hz and the sound pressure level (SPL). Now the number of waves has absolutely nothing to do with the strength or power, the height of the wave does. Just like at a lake/ocean a single wave of a medium height hits the shoreline it does little damdage. Now if you increase the number of waves at the same level, pressure on that particular medium (shore) increases and if you add waves that are higher (more power) the pressure increases even more (at the same number of waves). This is a crude representation but it is meant for more to understand, lol. Hope this helps...Polo. :-)
Chicago, IL US
Post Number: 469
I hate that saying, "brown note", makes me think of brown eye, lol...
GOT BROWN? LOL :-O
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 480
lmao, I wish she would deliver my amp I am getting this Sat. I can always dream.
