BOSE - sub integration -- HELP!
Username: Addygirl
I have a Bose spare-tire subwoofer from a Nissan 2003 Murano. I would like to find out if I can use this on another vehicle with an aftermarket receiver.
If so, is this Bose-sub self powered or needs amplification? Second, does anybody know the wiring schematics to the Bose Sub to directly connect to afermarket system?
Thanks for your help!!!!
Username: Logan__tille
Post Number: 35
yes you can use it, no it doesnt need to be amplified but it would perform better if it was.
Username: Addygirl
Thanks logan tille,
Can you "double-up" on a pre-amplified speaker? And do you happen to know the wiring schematics to the Bose system where I can connect the constant, ground, ignition, and trigger wires?
Much appreciated!!!
Username: Lexuscoop
Post Number: 1167
you have to look in your manual, or ask nissan. or look it up on the internet with the type of sub and the number it is.
