Bronze Member Username: Audiowizard69Post Number: 78 Registered: Nov-05 | is there any way of grounding an amp to something besides the negative post on a battery? i am asking because i am putting a car system in my house and i wanted to know. |
Bronze Member Username: Bachatero07Post Number: 48 Registered: Mar-06 | easy answer. dont do it. mainly because you wont find any permanent dc power strong enough for the amp. for instance, a 12v plug from your old cordless phone will NOT be strong anough for the amp. and if you plan on using a car battery, you will drain it pretty quickly. |
Bronze Member Username: Audiowizard69Post Number: 80 Registered: Nov-05 | i am going to use a battery charger on the battery that has a trickle setting.but please someone help. dennis didnt giv an answer i was looking for |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1597 Registered: Dec-04 | And where will you keep said battery and charger, emitting explosive gasses and requiring regular maintenance? It don't frigging work. |
Bronze Member Username: Bachatero07Post Number: 62 Registered: Mar-06 | if you really want to do it then just stick the ground wire into the third prong of a grounded outlet. but we are all going to keep telling you the same thing. dont do it. its dangerous and very inefficient. |
Bronze Member Username: Bass_manPost Number: 13 Registered: Mar-06 | If you have an amp that draws in 25 amps or less, you can pick up an AC-to-DC power supply from Radio Shack for around $100. I did, and used it for nearly two years, but then i blew up my amp. lol. You can also power any other 12V stuff off of it. Here is a link to it on Radio Shack's website... http://www.radioshack.com/product/index.jsp?productId=2103961&cp=&kw=power+suppl y&parentPage=search |
New member Username: Audioluv2222Cambridge , Ontario Canada Post Number: 2 Registered: Mar-06 | I was wondering how to power my amp off of a switching power supply, i currently have 2x Soundstorm DC-112DVC Car Audio 12 Inch Sub Woofer Speakers(RMS Power Handling:450 Watts),and a Soundstorm F350.2 Car Audio 2 Channel Sub Woofer Speaker Amp Amplifier (350W rms x 2) My Subs: http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1331953/vpcsid/0 /SFV/30046/sret/1621121621521422122028122219282219228285216229234289220229226295 232237236233226231228245232231244 My Amp: http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1541536/vpcsid/0 /SFV/30046/sret/1621121621521422122028122219282219228285216229234289220229226295 232237236233226233234231234245246 I was would like to know everything i need to know about being able to power my amp off of a computer power supply, before i go out and buy one, can someone please email me with pictures/instructions on how to do so at * zane_mike2k4@hotmail.com Thanks |
Bronze Member Username: Bachatero07Post Number: 65 Registered: Mar-06 | many people have come and gone trying to connect a car audio system from a computer power supply. i'm a computer tech so trust me when I tell you that a computer power supply will not have enough amps to power the system. like i told the first guy, connecting a car amp in a home, is never a good idea, but if you aboslutly have to do it for some reason follow what greg says. even though you'll most likely blow something sooner or later. |
Silver Member Username: Nnnnick_bWeddington, Nc Usa Post Number: 464 Registered: Jan-05 | http://www.bills2way.com/equip/ps52.html 45 amps @ 12-15volts That will work as long as your fuse rating on you amp is at or below 45 amps. |
Silver Member Username: Nnnnick_bWeddington, Nc Usa Post Number: 465 Registered: Jan-05 | http://www.buyreliant.com/psupplies/ps86.htm This one is 80 amps 12-15volts |
Silver Member Username: Nnnnick_bWeddington, Nc Usa Post Number: 467 Registered: Jan-05 | You could get about 850rms out of the 80 amp one. |
