i got a concept 650 andlooking to install a mobile phone pager unit but dont know if i have the correct wire.
i need a wire that produces a constant signal when the alarm is triggered. Prefably this should be negative but a positive one will do, as i change chnage the polity with a relay
anyone know if the unit has the wire in question or if anyone has an installation manual for it.
