Username: Strm777 Post Number: 1 Registered: Mar-06
Monday, March 13, 2006 - 01:48 GMT Hi. I am not able to load new bin files for Fortec Ultra lifetime receiver. If someone can help me. System info is its 272 and boot version 5. When connected to PC with RS 232 null modem cable, not able to upload file.
Username: Leew Ketchikan,
ALASKA
Post Number: 311 Registered: Jan-06
Monday, March 13, 2006 - 01:52 GMT Select the correct serial com port settings (ie. COM 1) and ensure the default Baud Rate is set to 115200. File Type should be defaulted to App File Only.
ALASKA
Post Number: 312 Registered: Jan-06
Monday, March 13, 2006 - 01:55 GMT
ALASKA
Post Number: 313 Registered: Jan-06
Monday, March 13, 2006 - 01:57 GMT don't look on #BIN, it's old one, for pansat
Username: Strm777 Post Number: 2 Registered: Mar-06
Monday, March 13, 2006 - 01:59 GMT Which loader should I use ?
ALASKA
Post Number: 314 Registered: Jan-06
Monday, March 13, 2006 - 02:00 GMT I mean here:
Username: Strm777 Post Number: 3 Registered: Mar-06
Monday, March 13, 2006 - 02:01 GMT whick uploader should i use for app file? Giving me same error.
ALASKA
Post Number: 315 Registered: Jan-06
Monday, March 13, 2006 - 02:02 GMT use this link:http://forums.dsstester.c om/vbb/forumdisplay.php?f=115
ALASKA
Post Number: 316 Registered: Jan-06
Monday, March 13, 2006 - 02:03 GMT copy and paste,to add br. make com
Username: Strm777 Post Number: 4 Registered: Mar-06
Monday, March 13, 2006 - 02:07 GMT I have to use null modem cable or other cable (straight connection)
ALASKA
Post Number: 317 Registered: Jan-06
Monday, March 13, 2006 - 02:24 GMT Need straight db9 and upload software to download the bin file to your system
Username: Lklives Post Number: 1353 Registered: Jan-06
Monday, March 13, 2006 - 02:39 GMT Ultra does NOT use the null modem cable as U stated in your first post!...thats why u got 'flash failed"....U MUST use the straight DB9..
Username: Ashkit Post Number: 14 Registered: Dec-05
Monday, March 13, 2006 - 16:55 GMT For uploading 272T2 bin file for FLU, I used a straight connection DB9 cable as LK mentioned and Black List uploader. Hope this helps.
Username: Akdigital Edmonton,
Alberta
Tuesday, March 14, 2006 - 05:35 GMT fortec Lifetime Ultra------>>>Pansat 2500 Need file, how to, stb loader,
Username: Arestras Post Number: 1 Registered: Mar-06
Tuesday, March 14, 2006 - 12:30 GMT Can anyo1 tell me what to now ? i accidentally installed the ultra software on the lifetime Diamond
