Bronze Member Username: HalterOhio Post Number: 76 Registered: Oct-05 | I have a club cab dodge truck..I am going to make me a big ole box put on the bench seat....or a box that meets the speq of whatever sub...but I want to know what sub to use...I wanna spend about 350 max for 2 12's ...and I would rather have spl...what should I get |
Gold Member Username: RovinTrinidad & T... Post Number: 6409 Registered: Jul-05 | need SPL ? - then check out kicker L5 or L7 subs , should fall right into ur budget ......... |
Bronze Member Username: HalterOhio Post Number: 77 Registered: Oct-05 | the hit pretty hard...my buddy had 2 12" powerplants (fusion)..are they about the same as them? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1426 Registered: Aug-05 | Ok, skip the Solobaric series subs. Bad idea. Get the CVX woofers. You won't have all the spider/surround problems, and you'll have MUCH better sound quality, and still get your high numbers you're looking for! |
Bronze Member Username: HalterOhio Post Number: 78 Registered: Oct-05 | soo..kicker cvx 12 inch...now....would that be as good as a fusion power plant?? |
Bronze Member Username: Talon_es93Post Number: 26 Registered: Mar-06 | i think i would go with the solobarics...i've heard both.. the L7s and the CVX and the CVXs had more power to them.... i think solobarics maybe even the L5s would be better but like most other ppl here are thinkin.... wtf do i know i'm only 17 |
Bronze Member Username: HalterOhio Post Number: 79 Registered: Oct-05 | ahha thats what I am thinking..I am only 16..I know how to hook the shtuff up but I dont know about all the subs yet...I haven't heard all of them..I just want them to be atleast good as the powerplant..if not I get them...and I will be running a Audiobahn A8002T amp also |
Bronze Member Username: Talon_es93Post Number: 27 Registered: Mar-06 | i've had good luck with audiobahn and got some sh!t to bump pretty good but i odn't think any one here likes audiobahn |
Gold Member Username: RovinTrinidad & T... Post Number: 6419 Registered: Jul-05 | u said above u wanted SPL so i thought u had an idea & ur budget is also small too - thats y i said L5/L7 . Subs that sound better but maybe not as quite loud as those kickers & fall within budget Cerwin vega VMAX Kicker CompVR Alpine Type R etc....... |
Bronze Member Username: NypdlapdPost Number: 35 Registered: Feb-06 | Audiobann is a GOOD company!! |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1427 Registered: Aug-05 | I'm 18, and I've been around here, as well as I have a dad who's extremely knowledgeable about audio and electronics and MUCH MUCH more. But sometimes, he tells me more than what I wish to know... Anyways, just stick around, you'll start getting the idea of how stuff works, just takes time. I think the CVX will be as good if not better than the powerplant. The CVX is a ROUND L7. Sure, it doesn't push as much of the claimed air...But if the excursion is increased to make up for lack of surface area, I don't see how it'd be a supposed problem... Of course, excursion is just one of the many things that lead to greater SPLs. Anyways, go with the CVX. It's in the same price range, and will be very loud. Also, you could look into the Ascendant Audio Assassin, or something from Digital Designs. RE Audio has 12" subwoofers that are very nice and loud with SQ as well. There's a lot more options out there other than Kicker. |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1428 Registered: Aug-05 | I'd put the new CV V-Max up against the CVX anyday. That's the idea behind most if not all CV products, be able to handle a lot of power, but still play loudly with good sound quality with LESS power. It's a neat concept. AA has adopted a similar concept with their new line, but they have better sound quality, and are louder yet. |
Bronze Member Username: Talon_es93Post Number: 29 Registered: Mar-06 | ya i liked audiobahn to...i have one 12" immortal and it sounded better then my 2 12" type-rs..... Rovin ik uk alot more stuff then me but i think i disagree with you on the type-rs i think the L7s would sound much better |
Gold Member Username: RovinTrinidad & T... Post Number: 6421 Registered: Jul-05 | well a R is = 500wrms & a L7 = 750wrms so of course thats comparing oranges & apples ... oh & we all 4got 2 mention www.reaudio.com ecoustic's members fav brand -lol Look @ their SE models ... |
Gold Member Username: RovinTrinidad & T... Post Number: 6422 Registered: Jul-05 | well a R is = 500wrms & a L7 = 750wrms so of course thats comparing oranges & apples ... oh & we all 4got 2 mention www.reaudio.com ecoustic members' fav brand -lol Look @ their SE models ... |
Bronze Member Username: HalterOhio Post Number: 80 Registered: Oct-05 | well ok another question...if I would go with the L7s or teh CVX either or....there watts are 750watt rms and 1500max...ok..since I only have 1 A8002T amp.. 1600 max.... I wouldn't push them all the way...so would that hurt them or what? |
Bronze Member Username: HalterOhio Post Number: 82 Registered: Oct-05 | bump |
Bronze Member Username: HalterOhio Post Number: 83 Registered: Oct-05 | ??anyone |
Gold Member Username: RovinTrinidad & T... Post Number: 6436 Registered: Jul-05 | not a very powerful amp & it would push ONLY 1 of those subs ........ |
Bronze Member Username: HalterOhio Post Number: 84 Registered: Oct-05 | what amp would u get?? |
Gold Member Username: RovinTrinidad & T... Post Number: 6443 Registered: Jul-05 | if u like those kickers - try the new CVX which said 2 be better than the previuos models , haven't heard it yet though .... u should always get an amp that is slightly oversized . So like in ur case where u its rec 1500wrms i would get a true 2000wrms amp or 2 1000wrms each amps like RF T200001bd (there aren't many 2000wrms amps mostly 2500wrms amps models) or 2 hifonics bx1205d if on a budget maybe 1 of these http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3506 ..... |
