Silver Member Username: Terry6405Sullivan, IN US Post Number: 525 Registered: Sep-05 | i was wondering, could someone (lets say me) fabricate a box compleatly out of plexiglass? i think that would be neat because you could totally see the inside of the driver how much would it cost for a 4x8 sheet of it? i donno, lets say half an inch thick, and would it be very difficult to build? |
Gold Member Username: LexuscoopPost Number: 1098 Registered: Dec-05 | very hard to make look clean, they don't sound as good as a MDF. they are EXTREEMLY expensive you would ned 3/4 to 1 inch thick |
Silver Member Username: Terry6405Sullivan, IN US Post Number: 526 Registered: Sep-05 | hah ok forget that |
Silver Member Username: RzarectorCoquitlam, Bc Canada Post Number: 973 Registered: Dec-04 | yeh pointless .. for a 3/4" sheet of lexan your lookin at like a grand or more |
Silver Member Username: Terry6405Sullivan, IN US Post Number: 531 Registered: Sep-05 | i dont think its that much |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2380 Registered: Mar-04 | http://k-mac-plastics.net/plexiglass-acrylic-sheet.htm 49"x96"-3/4" thick clear plexy...$773.28 |
Bronze Member Username: WinterfreshpimpChisago, MN America Post Number: 39 Registered: Mar-06 | you couldnt afford to mess up man! you could make a normal 3/4 inch mdf box and have the bax be plexi, that looks tight! i saw a box with the guys name engrave in it all crazy and what not... it looked hella pro! |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2314 Registered: Sep-04 | http://cgi.ebay.com/15-STANDARD-ACRYLIC-SINGLE-SUBWOOFER-BOX_W0QQitemZ5806143241 QQcategoryZ50568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem i wouldnt buy it but... |
