Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1926 Registered: Dec-05 | im ordering a 12'' diamond d6 this weekend and i wanna go ahead and order some 5x7 coaxials for the front...i dont wanna spend more than $120 though any suggestions..i was thinking maybe the diamond d3 speakers |
Gold Member Username: LexuscoopPost Number: 1084 Registered: Dec-05 | isn't diamond a good brand? |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1927 Registered: Dec-05 | yep...i hope so anyway lol |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1930 Registered: Dec-05 | http://sonicelectronix.com/cat_37.html heres the page im going to choose one of them from there..im getting the sub there so im gonna go ahead and order the subs there too...im thinking about the jl's for 89.99 |
Gold Member Username: RovinTrinidad & T... Post Number: 6371 Registered: Jul-05 | can't u fit 6.5" comps with a spacer ???......... |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1931 Registered: Dec-05 | idk im not wanting to spend too much money because i dont know how much longer ill have the truck but i wanna get something besides the shitt y stocks |
Gold Member Username: RovinTrinidad & T... Post Number: 6373 Registered: Jul-05 | around 100 bux u can get a pair of 6.5" Inf Refs comps on ebay - i have 2 pairs & they r decent...... |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1933 Registered: Dec-05 | what amp u usin ? |
Gold Member Username: RovinTrinidad & T... Post Number: 6377 Registered: Jul-05 | https://www.ecoustics.com/electronics/forum/car-audio/189456.html |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1934 Registered: Dec-05 | if u had to get some from the page i posted which would u get |
Gold Member Username: RovinTrinidad & T... Post Number: 6381 Registered: Jul-05 | never really had cause 2 use 5x7 cause its usually 6.5 or 6x9 tough choice cause i find it hard imo 2 those prices 4 coax when comps r almost same $ if i were forced 2 make a choice on that page - http://sonicelectronix.com/item_4813.html ...... |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1935 Registered: Dec-05 | well i dont wanna get comps because i dont wanna have to amp them because im already getting alot of blinking from my headlights |
Gold Member Username: RovinTrinidad & T... Post Number: 6385 Registered: Jul-05 | Oh , ok well i'd advise u 2morrow 2 go measure the holes & see if u can still fit in some decent 50wrms 6.5" COAX in there & i think i read that its bass amps is what really pulls current & not smaller speaker amps ...... |
Silver Member Username: MixneffectOrangevale, Ca. USA Post Number: 856 Registered: Apr-05 | My buddy that got me started in this hobby worked for a build house that designed/engineered/built drivers for Diamond Audio. I am not biast because its my buddy and that he is my audio mentor, but I actually listened to diamond products, and I find them to be better than Focal, MB Quart, and a few other name brands out there. As far as oval shaped drivers are concerned, I am not familiar with their line-up in that size, and I am not a fan of those shapes, but what I know is that it is the crossover and the tweeter that makes or breaks component sets, not size and/or shape. Component sets are ment to deliver the midrange. This area is most sensitive to the human ear. So look for a set that is transperant, smooth (especially between 800 hz to 6 Khz). This is the crossover knee region. It is also the break-up point. If you care for quality, this will matter. |
New member Username: Cowboyup3004Post Number: 6 Registered: Mar-06 | I have 2 Diamond 10" subs in my 95 ford F-150..they are on an 400 watt Audiobahn Street mashine amp...My head lights dim too lol..But I absolutly love my Diamonds....aslong as I keep the amp turned down..I tryed to show off last week and blew out the back glass in my truch...no fun at all.. |
