Please help Rovin or somebody...
Username: Thomas_g
NM
Post Number: 128
I just ordered the Kicker 05CVR122 CompVR 12" 2-Ohm Subwoofer at etronics.com but i dont know if it is dual voice coil or just single. I need a 2ohm dual. I noticed it didnt have a photo so i couldnt tell, but everywhere else i look at on the internet says it has 2 coils. So what do you think? Do you think it probably does have 2 coils and it just doesnt say?? Thanx
Username: Thomas_g
NM
Post Number: 129
http://www.etronics.com/product.asp?stk_code=kic05cvr122
Is the link at etronics.
Username: Rovin
Trinidad & T...
Post Number: 6451
i think ur safe - its 2ohms DVC
http://sonicelectronix.com/item_3406.html ......
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 677
dual 2ohm.
Username: Thomas_g
NM
Post Number: 130
Thank you guys very much got 2 go peace.
