2 ohm or 4 ohm?
Username: Jleet68
Post Number: 10
I plan on getting 2 12" L7's, and a KX1200.1 amp which is 1 ohm stable. So should i get 2 ohm subs and wire them to a 1 ohm load, right?
Username: Tjmutlow
Post Number: 1613
no, dual 4 ohm subs(2 of them) load to a 1ohm load.
Username: Rovin
Trinidad & T...
Post Number: 6353
Wrong ! - buy 2) 4ohms dvc subs
Username: Rovin
Trinidad & T...
Post Number: 6354
BTW - a 12" L7 = 750wrms
& a 12" L5 = 600wrms
i'd say 2 L5 would be better suited 4 that amp ......
Username: Nnnnick_b
Nc Usa
Post Number: 433
I would have to disagree, a kx1200.1 will bench around 1450 watts rms @ 1 ohm. Highly underrated. Thats atleast 700 watts rms per sub. I would get the L7's. IMO
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 671
comp VXs...
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1331
i'd screw them all and get some RE se's, or AA aresenals, if the vc config is right.
