JBL cinema sound series
Username: Deepak
like to know which amp to use with the jbl cinema sound speakers. i have a few names in mind like NADs, denon, marants. main use will be for HT any suggestions.
Username: Deepak
can this forum answer a question of this caliber
Username: Project6
Post Number: 6799
Wonderful attitude newbie.
Do you have a budget? What is available in your area?
Without any of this information you can basically pick any receiver you want.
Username: Deepak
Berny my apologies. the cinema sound are JBL speakers. its a 5.1 channel with a subwoofer. if u go to the jbl web site u will see the Cinema Sound Series. i have heard it with the Denon but have not tried it with any other receiver. would Nad or any other receiver sound better with the Cinema Sound. my room size is about 25 sq meters. the budget is 1500 dollars for the receiver only. thankyou
Username: Chitown
Post Number: 862
For HT use you can pretty much go with any of these receivers or Outlaw. People here have been dissatisfied with the hissing noices from the NAD T series. So you may want to consider it.
Username: Deepak
which one will be the best for HT. thankyou
Username: Deepak
would the sherwood be a good match?
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1601
Sure it would.
Deepak, just about anything will run a theater.
Buy the Denon.
Or a nice H/K.
See, the difference is when you want the thing for music as well as movies, then it gets thick.
Username: Project6
Post Number: 6908
Absolutely. Why not check out the Outlaw Model 1070? It will drive those JBLs really well.
Username: Deepak
the outlaw is only 65watts will that be ok for the 150 watts speakers
Username: Project6
Post Number: 6939
Yes, the Outlaw will have more than enough power for your speakers.
And just so you know...speakers don't have watts.
Username: Deepak
Post Number: 7
Berny in your opion what do u suggest for serious HT use only. my buget is about 3 grand only for a 5.1 setup and a av receiver
Username: Tdogroeder
Des Moines, IA
Post Number: 117
There are a lot of options out there for $3000. Check out your local audio shops and go listen. Paradigm, PSB, JM-Lab, etc.... Have fun & enjoy!
